Question about Kodak EasyShare C633 Digital Camera
I have a kodak easy share c633 and even though I put good batteries in the scope will not come out to take pictures. What can I do? Thanks
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 22, 2010
Kodak easy share is frozen on the Easy share page
Remove the battery and the memory card, and disconnect from computer, now push power and hold for at least 60 seconds to reset the processor ic, install memory card and battery, turn on camera settings should return to normal, if not! the systems control board is the problem.
Apr 16, 2012 | Cameras
Camera powers on and dies immediately
There was a problem with your Kodak system which is very critical to do it by yourself. It is better to check it with Kodak repair shop.
Please rate me solved if you like my solution.
Best regards,
Philip
Nov 13, 2007 | Kodak EasyShare C633 Digital Camera
Camera turns on..sometimes turns off again...if lucky will take a picture before it turns off again.. the battery is flashing even though I have just changed them
My Kodak Easy Share C433 camera does the same thing! Does anyone have a solution?
"camera turns on..sometimes turns off again...if lucky will take a picture before it turns off again.. the battery is flashing even though I have just changed them"
Sep 22, 2011 | Kodak EasyShare C433 Digital Camera
I am trying to download photos to my pc. All plugged in the the Device Connected box ins blank. Any ideas - its driving me nuts!
OK, when I use my Kodak Easy share cameras on a fresh computer that hasn't downloaded Kodak pictures before I do the following:
Load Easyshare software onto the machine, and install it.
Then, I connect the camera to the computer.
Then, I open the Easyshare software and it may ask a few questions.
Next, I watch the computer (Windows 7) as it loads the proper driver for my camera.
Finally, I click on transfer pictures and I am set with my pictures.
The pictures should show up in the Start Menu's picture under Kodak Pictures.
You should be done.
Let me know how it works out with the Easyshare software downloaded to the computer before trying to load pictures on to the computer.
Jul 10, 2010 | Kodak EasyShare C633 Digital Camera
The kodake easy share c633 wont turn on even with new battries
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 05, 2009 | Kodak EasyShare C633 Digital Camera
Camera will not turn on and battery is fully charged
Hi I am Vortash I know this might sound silly but check the battery is in the correct way round .. if your like me and changed the batteries to my easy share I forgot a couple of times and put them in the wrong way round ..( even we make mistakes ) reversersal of the batteries cured my problem and added to my embaressment lol .. other than that check the batteries havent leaked and if they have look in the battery compartment for signs of damage rust etc .. and if you are still using the easy share battery that came with the camera .. it might say it is charged but may not be mine was dead and wouldnt charge afyer about 6 months use .. Regards Vortash
May 17, 2009 | Fuji FinePix F10 Digital Camera
Kodak Easy Share C633
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sep 14, 2008 | Kodak EasyShare C633 Digital Camera
I can not get my Kodak Easy share c633 and c300 to turn on
have you checked the battery terminals if they have rusts where the battery sits?
Jul 27, 2008 | Kodak EasyShare One Digital Camera
Power On the Kodak C633
akaline batteries batteries are not powerful enough to last more than a few shots, maybe 15 or 20 depending on the lcd screen if its running all that time.
use a much heavier NiMh (nickel metal hydride)
they last for 50 to 100 shots.
if you still have the issue then its a camera circuit issue
Consider rechargeable as they save a fortune
Apr 13, 2008 | Kodak EasyShare C633 Digital Camera
I lost my cd for my kodak easy share c633
Sorry to hear your lost your disk -
http://www.kodak.com/global/en/service/downloads/dln_ekn031211.jhtml?pq-path=6839/8749/8750
That is a link to the website from Kodak that has the drivers and software for your camera. Just download the software, install it and you should be good.
Let me know if you have any other problems!
Nov 18, 2007 | Kodak EasyShare C633 Digital Camera
Kodak EasyShare  C633 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
