Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
MY bissell is leaking water from underneath - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Corrosion around the screw on the heater
Posted on Jul 06, 2015
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ewqrtrq
Posted on Sep 30, 2010
My Bissell Proheat Clearview 1699 starts leaking water when I power it on.
There are many hoses, fittings, valves, jets, etc. in addition to the pump and heater that all a possible source of your water leak. You must inspect and test all these areas thoroughly to diagnose the source of your leak.
Oct 17, 2017 | Bissell Vacuums
Bissell instruction manuals
The instructions tell you to clean filters after each use. Check the User's Guide for specifics. Quick guide though. Water tank Cap: Under the cap is filter (looks like a screen) remove, clean, replace. Locate the Flow Indicator: turn it counter-clockwise to remove the cap. Lift out the rotor and the filter underneath, Clean and reinstall in reverse order. That should fix the problem. Consumer Care phone number is listed in the User's Guide.
Aug 20, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 2xs
THE JETS UNDERNEATH THE MACHINE THAT SHOOT THE WATER OUT ARE PROBLY CLOGGED WITH DETERGENT. Get a pin and try to clean them from underneath the machine . Ten put some hot , hot water in and wait about 5 mins. then try it out.
Dec 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
It is leaking water from the bottom
I had this problem, and after some research found out I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
I purchased this gasket from Bissell for 1.39 and the suction is night and day. No more leaks. I purchased my SpotBot Bissell new at Target, so I have no idea where the black gasket went.
Jul 07, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
445 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
