Question about Uniden Lands Phones
ONE PHONE OUY OF 6 WILL NOT DISPLAY INCOMING OR OUTGOING mCALLS. hAVE BASE + 5 EXT. MODEL #TRU9488-3WX
  • rpdlnc Aug 24, 2010
    I tried the recommended advise to fix the Un iden phone that was not showing on screen incoming & outgoing calls. NOW, I DON'T GET A DIAL TONE SO THE ENTIRE PHONE IS NOT WORKING
  • 1,606 Answers
If that phone is working normally ie you can use it to talk and make calls on then I'd say the problem is internal which basically means replacing it. If you have trouble connecting or making calls then it can be location or a signal problem.
I would suspect that you will need to replace it but before you do that try de-registering it fro the base and then re-register it. I don't have the manual for that model handy so I can;t give you the page. Usually its under the setup menu section. If you can't find yours, you can download a pdf version of it from Uniden as well from their support section. To do the dereg-rereg only takes a few minutes. Unfortunetly other than batteries there is little than can be fixed on the handsets. so if it is a cpu or display problem all you can do is send it in hopefully under warrenty or buy a new handset for about $45ish.
Posted on Aug 25, 2010
  • Uniden Master
  • 19,396 Answers
Hi.
If phone takes calls, but calls are not displayed in the extension try resetting and re-synching the whole system.
Disconnect all base units from power and remove all handset batteries.
Wait ten minutes, put back batteries, sit handsets in cradles and connect cradles to power.
That should reset the system, if that does not work, one unit (probably main base) is faulty, and it is causing the whole system malfunction.
Note: If phone does not take calls at all, then it is likely phone cable or line.
Posted on Aug 22, 2010
Display on base unit is blank - handsets display "Searching". This is a DECT 6.0 system.
Please provide me with your model number so that I can help you.
Jul 29, 2015 | Uniden Lands Phones
There is now no ring associated with incoming calls on line 3, but otherwise that line functions for both incoming and outgoing calls
http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
page 80,do this first,
25611223-5sp5orn0xnhdqraxk0v0421v-4-0.png then if you want to reset both phone and base,
clear base unit settings to default,
1 Press {MENU}. 2 Scroll to "Initial setting" by pressing {<} or {>}, then press {ENTER}. 3 Scroll to "Initialize base" by pressing {<} or {>}, then press {ENTER}. 4 Scroll to "Clear settings" by pressing {<} or {>}, then press {ENTER}. L The "Clear settings?" screen is displayed. 5 Press {CLEAR}. L Confirmation tone is heard.
clear handset to default,
Press {MENU}. 2 Scroll to "Initial setting" by pressing {V} or {^}, then press . 3 Scroll to "Initialize HS" by pressing {V} or {^}, then press . 4 Scroll to "Clear settings" by pressing {V} or {^}, then press . L The "Clear settings?" screen is displayed. 5 Press . L Confirmation tone is heard.
Mar 27, 2015 | Panasonic KX-TG4500 Phone
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
heard.
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
messages".
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
How do I retrieve a missed call from a Motorola Moto G Ext cellular phone?
Phone > Recent (clock icon) then look for items that have red arrow. Blue is incoming answered. Green is outgoing.
Mark
Motorola Support
Dec 16, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
Unit does not make outgoing calls nor receive incoming calls. Display seems OK but tiny vertical bar top RH corner doesn't flash 9should it?). Unit is fully charged. Trying to call IT from cellphone gives...
Friend i think u r cell phone setting are mess up
so please go to ur cell phone setting and go to security and then try to find restriction menu and then turn of it if u find it then
u got
three options like
outgoing call
incoming call
messege
phone book restriction
so set it unselect
Jul 22, 2009 | Cell Phones
How to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
Jul 17, 2009 | Panasonic KX-TGA101S Cordless Handset
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Clearing incoming & outgoing calls data base
Go to the calls you want to erase and press opitions and it should say delete.I THINK
Jan 03, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
