Verticle output ic
Where will I find this verticle output ic on my tv and what does it look like?
  • 8,617 Answers
Its a small black IC mounted to an aluminum heatsink on the tvs main circuit board
Posted on May 03, 2008
Half of the TV screen went black with a bright white line splitting the screen horizontally.
it's eather your Verticle output ic ... i dont know what the part number is but shude be easy to look up ...... or maybe your yoak (this would not be normal) ..... i would bet on the IC and maybe some captors no way to know without changing out the ic and seeing
Feb 15, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Dear sir have sony tv dr 29m93 and and have verticle sinc problem and menu displey not showing can u guid me for this problem
take the tv to a repair shop, a verticle problem is not a major one. verticle has a ic, a output capacitor electrolitic which can dry up, and a scan coil on the tube. on the scan coil we have 4 wires two wires go to a line trasfirmer for horizontal, and two to an ic via a capacitor and ground.
ask the tech check what i have told you.
Jan 05, 2010 | Sony KV-DR29M69 29" TV
Where is the verticle output IC on my 52 inch rca projection tv
if you remove the rear panel you will see the board on the far left has a large transformer with a large red HV cable coming out of it. Thats the flyback. Now look to the right side of that board in line with the flyback. The aluminum heat sink with the fins has the verticle IC. Its the first heatsink closest to where youre looking on the right side of the board with the flyback.
Dec 06, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture folding over at top of screen
Verticle IC needs replaced and also the sodered connections could be bad at the high voltage transformer.
Oct 14, 2009 | Sanyo AVM-3659S 36" TV
When I run the Touch Focus , it ends Touch Focus Error, and the Red Verticle line does not move , the Horizontal is bent .. now tv is fuzzy?
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | Toshiba 42H82 42" Rear Projection...
Verticle black line
just on a whim I'd say you have vertical output IC circuits in distress.
can you say Warrenty :->
Jun 10, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Followup question on the advice to pass on the $100 tv.
no its a DLP they are having some troubles with the dlps losing signal due to the digital board. verticle ICs only effect CRT projections by making the CRTs shutdown . Dlps are all controlled by the digital board. They are very expensive when you can find them. They are usually over 800 and need to be special orderd. I would pass on the TV. You can buy one cheaper than fix that
Mar 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Sanyo DS25390 Vertical problem
Jack,Did the Vert Ic have Broken conns around the legs?
Most of the time when theres no picture on a mitsubishi projection set, theres no verticle sweep. Most likly cause is the verticle output IC or the b+ feeding the IC or Both. This is not a consermer replaceable parts. It could also be the PIP module if the set has one . Remember these sets have alot of hi-voltage even when the sets unplugged. Good Luck
Jun 22, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
