My washer is a model #110-1650290 washer dryer combo. The problem occured during the last wash. It would not go through the spin cycle. I dismantalled the housing to inspect and found a small black pile of dust on the floor assuming it came from the previous belt. At this point it would be very helpful to acuire a manual for the above model.
catriver
  • 878 Answers
SOURCE: Noisy spin cycle
Hey ****, what you are hearing is the spin bearing. Maytag redesigned the bearing kit on this washer, there must of been a lot of leaks causing the bearing to go bad. They put out a service flash...TDL-0060-B. New seal and bearing kit, part number12002470. You may want to contact Maytag on this for it could be covered. I know you have 5 years warranty on the transmission and If they change that, they have to use a new seal and bearing. Catriver...post back.
Posted on Oct 06, 2006
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
  • 686 Answers
SOURCE: Whirlpool washer does not spin, water drains but does not spin.
That would be your "motor to transmission coupling go to www.repairclinic.com and enter your model number. It will show you what the part looks like. It will be the first part you see when you get there.
Posted on Apr 03, 2009
SOURCE: Supra Wash/dryer combo Model SW5l30D
check the heating element for power.
Posted on May 03, 2009
  • 3741 Answers
SOURCE: Washer will not spin for
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 11, 2009
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wsm2480dww laundry center(combo)
The washer drains the water durring the neutral drain. (water drains out but the basket does not spin). Then the timer will hit a "pause" (basically removes the power momentraily so the gear case can change gears). So if you are not getting the pause durring the cycle, lifting the lid does the exact same thing. I would agree with you from your last comments that you do have a timer issue. They can be ordered on line from the manufacture or more readily a local appliance parts store.
Jul 10, 2008 | GE WSM2480DWW Large Capacity Washer & Gas...
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
