Question about Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit
My Sirius Sportster 5 satellite radio wont turn on sitting in the cradle in my car. It’s powered by the cigarette lighter in my car, not custom installed. How can I run a diagnostic on the radio to see if it’s a problem with the radio itself or something else? I am able to power my Garmin from the same cigarette lighter.
2 Suggested Answers
  • 161 Answers
SOURCE: my fuse blows everytime i plug in my sirius radio
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
Posted on May 12, 2010
How does a audovox sirius pnp3 work, how to hook up in c ar
The cradle connects to the cigarette lighter connection for power. There is a connection for the Magnet mount antenna which sticks to the roof. The radio can output a radio frequency signal which you can tune your fm radio to receive. It has a number of frequencies to choose from so you can try to find one that is quiet and works best.
Mar 29, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
My sirius sporter 5 keep turning off and on while driving
Power or Signal drop-off can be fix at ebay item# 360454042820
http://www.ebay.com/itm/ 360454042820
Dec 12, 2011 | Sirius Sportster 5 Satellite Radio...
Losing signal on sportster 5 Tooth on bottom appears damaged can this be repaired
take it to radio shack and ask them, they may be able to help you find a replacement
May 20, 2010 | Sirius Sportster 5 Satellite Radio...
SIRIUS S50 radio car kit won't turn on
It may be that the dock isn't working, I would return it for a new one to the place that you bought it from to make sure that you have a dock that works.
Apr 18, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius Sportster
Look at the bottom of your unit, you'll notice the round port next to the slot? It get's jammed up inside the unit if you pressed to hard setting it into the cradle at some point. Not easy to fix, unfortunatley.
Oct 22, 2007 | Sirius Satellite Radio Sirius Sportster...
Sportster 4 not working...
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
Oct 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
Sirius Sportster
Unfortunately this is a fairly common problem in the Sportster, caused by worn contacts in the tuner. Sometimes you can temporarily resolve the problem by wedging a thin piece of cardboard behind the tuner in the cradle, to create a better contact; but eventually it will just wear out again.
Jun 08, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit Logo
432 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
