Copystar 1635 Copier
I just plugged in a brand new Copystar 1635 copier and it is flashing an error code C-3100.
What does this mean and what can I do to rectify it?
Thanks for your help.
David
C3100 Scanner carriage problem The home position is not correct when the power is turned on or copying the document placed on the contact glass. Poor contact of the connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Defective scanner home position switch. Replace the scanner home position switch. Defective engine PWB. Replace the engine PWB and check for correct operation. Defective scanner motor. Replace the scanner motor
Posted on Aug 14, 2009
What is Error code 8-0 630?
my dear you chek heater unit and reast codes
in program
Jan 16, 2015 | Kyocera Copystar CS-1635 Copier
I have a brand new Copystar 1635 copier... I just plugged it in and it is flashing an error code C-3100
It is toner error, check the plastic strip in toner had been removed, try pulling out and putting back toner
May 03, 2008 | Office Equipment & Supplies
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
The error message displayed is "OP".
OP means open. check if all covers front and left covers are closed.
Dec 30, 2010 | Kyocera Copystar CS-1635 Copier
I have a brand new Copystar CS-3060 turn it on and a ERROR CODE 3100 appears on the screen what does this code mean please??????
The scanner is locked...look for some large yellow screws on the side of the machine or on the rear of the machine inside of a detent. Turn it left until it pops out to release the scanner.
Mar 11, 2010 | Kyocera CopyStar CS-3060 Black and White...
Hello
C6000 is the code for a heat unit error. Either a lamp is defective, or a thermal fuse blown or maybe a thermistor (heat sensing device) is dirty or bad.
Jun 24, 2009 | Kyocera Copystar CS-1635 Copier
64 people viewed this question
k24674
jasbo
jasbo
