Question about Sony KDF-E60A20 60 in. LCD HDTV
I have this sony kdf-e60a20
The picture turns off and on every 30 seconds i think. I tried taking the lamp out and cleaning it, put it all back in and it does it again. When this problem started i didnt even notice if the lamp light is on. All i know is when it goes off and on the power light stays on and i notice from behind the tv that the lamp is off and comes back on with it. Can you help me please?
Thanks.
James
  • Anonymous Jun 01, 2008
    The tv turns off and then back on every 30 seconds.
  • Anonymous Jan 05, 2009
    My TV is 2006 and the lamp turns on and off every 30 sec.can you help me?
    Sergeant:
  • 259 Answers
Lamp is monitored by an over-current protect circuit. When the lamp starts drawing a little more current than normal, the set starts shutting off the video and audio then in a couple minutes restrike the lamp. Unique to sony WEGA's, replace w/ new type xl-2200u, you should be o.k.
Posted on May 28, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My Sony KDF-E60A20 will turnoff (Picture & Sound) for about 25 seconds and then turn back on again. This will go on for a while. It may run for a long time then goes through this cycle again
It is clear symptoms that tv needs new lamp as old lamp has reached at end of its life.
Lamp replacement procedure is easy and would be written in user manual, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Apr 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Picture and sound cuts in and out
Lamp inside of your TV set is nearing end of lifespan. Replace it.
Feb 15, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a Sony KDF-E60A20...it blink red 5 times and video or audio. It happen all of a sudden...what could be the problem?
5 is a bad lamp ballast . but you should check the lamp first. those tv's don't always detect ballast trying to start the lamp correctly. especially if its even been repaired before . most service poeple dont put the hv detect wire back in the correct place so when the lamp goes bad the tv thinks the ballast is bad. listen for a little short buzz or crackle noise from the back of the tv when you try to turn it on . the buzz noise last about 1 second and should happen about every 30 secoinds 3 times . if you hear it only the lamp is probly bad. or its a bad ballast
Oct 04, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
May 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60' projection model # kdfe60a20
I finally wet out and bought the tv repair manual. Thought the problem had to be more than the bulb because i was losing sound too. Everything in hte repair manual brought me to the bulb or the ballast. I ordered a replacemant bulb. I spent about 150, which included overnight shipping. I replaced the bulb just before Thanksgiving and haven't had any problems as of yet....
Nov 06, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
