Question about Nikon D80 Digital Camera with 18-135mm Lens
How do i change the mirror lens - Nikon D80 Digital Camera with 18-135mm Lens
  • 2,517 Answers
Check the video its helps you.
Thank you.
Posted on Aug 21, 2010
The mirror only returns when lens removal, it appears that on his return back it locks when the lens is at infinity. Maybe problem whith the mirror glue???
Sounds like the back of the lens may be sticking too far into the mirror box and interfering with the mirror travel. There are also a couple of bumpers on the bottom of the mirror box, and the plastic has become soft and breaks off, allowing too much travel for the levers. Try another lens first. If it does it with all lenses then you will have to search out a repair facility that still does something so old.
Feb 08, 2014 | Ricoh KR-5 SUPER II 35mm SLR Camera
Pictures are dark
First, check if you're taking the lens cap off. If you're taking it off, then check your exposure. See if your light meter responds to changes in illumination. If everything seems fine, then check if the aperture of the lens works as intended. Then, without a lens nor film in bulb mode, check for the mirror and shutter to work properly. If the light meter, aperture, mirror or shutter seem to flaw, then get your camera serviced by an experienced camera repair technician.
Jan 28, 2014 | Minolta Maxxum 5000 35mm SLR Camera
Looking through viewfinder i see dirt & black specks
It depends where the dirt is. Following the light path, look at the rear surface of the lens. A dirty rear lens surface will have the most affect on picture quality or what you see in the viewfinder of any position in the light path. Like all optical cleaning procedures, hold the lens with the rear lens surface facing the ground so gravity will work with you. Start by blowing clean air on it using canned air or a blower such as a Rocket blower or ear syringe. If that is sufficient, do not continue the sequence. This holds true at the conclusion of each step because the more aggressive your cleaning becomes, the more risk there is of damage. If it is still dirty, gently brush it with a sable or camel hair brush. If that is not sufficient, gently wipe it with a dry lens photograph lens tissue (do not use coated tissues) or a microfiber cloth. Finally, as a last resort, dampen a corner of a lens tissue or microfiber cloth (do not put the wet solution directly on the lens) and gently wipe with a circular motion. Finish by wiping with a dry section of the tissue or cloth. Although the front surface of the lens is not as important, repeat the process for the front surface.
If you still see the dirt in the viewfinder, are two possible remaining locations; the bottom surface of the prism located above the mirror or the mirror.
Clean the prism first and avoid cleaning the mirror if possible, or any contact with the mirror. The prism can be cleaned following the sequence outlined above. If that doesn't work, the problem is the mirror.
CAUTION! The mirror is front surfaced and is very susceptible to scratches and other damage unlike a conventional mirror which is rear surfaced with the glass protecting the coating. Aggressive cleaning should be avoided.
Carefully follow step 1 of the lens cleaning procedure (air) and step 2 (brushing) if necessary. As far as the third and fourth steps, I would not use them myself because of the risk of mirror coating damage. It would be better to take your camera to a qualified repairman.
remove the lens and look above the mirror at the bottom of the viewfinder prism. If it is dirty, clean it as you would clean a lens surface. The next place to look is the mirror.
CAUTION! The mirror, unlike the mirror over your bathroom sink, is front surfaced and there is no glass between you and the delicate and easily damaged coating. Hold the camera with the mirror facing down so that gravity will work in your favor. If that does not work, I would stop and take it to a camera repairman because you do not want to risk scratching the surface by using lens tissue or cleaner.
Feb 05, 2013 | Nikon F100 35mm SLR Camera
How to clean the fungus off a Mirror on the inside of a 500mm Mirror lens
Unless you have a lens collimator and other gear needed to make sure you get the lens and mirrors aligned properly when you put it back together, don't even think about taking it apart. Take it to a reputable camera shop and have a trained professional do it.
Jan 30, 2013 | Samyang 500mm f8 Ultra Telephoto Manual...
How do I chang the turn signal bulb in a 1800 goldwing
on the bottom of the mirror is a hole in the middle. move mirror till you see the screw. remove screw. lift the bottom of the mirror and you will see to tabs holdin the mirror in on the top . lower mirror and it will come out.
Dec 27, 2011 | 2008 Honda GL 1800 Gold wing Deluxe
Can't see through viewfinder (it's all black) and cannot trip shutter or advance film. batteries are new and intact.
Remove the lens and look inside it. Do you see the mirror? If not, your mirror is stuck in the up position. Its flat up against the focusing screen. If the mirror is down, the problem is in the lens, or you still have the lens cap in place.
Check your manual under troubleshooting.
Try setting the shutter speed dial to the M90 position.
Also be sure the batteries are inserted correctly!!!!
If no change yet, you can try to put the mirror back down yourself. With the lens removed, set the camera on its back. You can use your fingers, but I suggest a toothpick cuz they won't leave fingerprints on the mirror and the toothpick should break before you exert enough pressure to really break something. So just try to return the mirror to the 45 degree angle within the mirror box. Be careful not to damage anything in there, like the shutter or the arms that raise and lower the mirror. Depending on where you live, there may be some corrosion or rust on the mirror linkage. It should move easily. If you feel any roughness when you move the miror, that may be the reason it did not return on its own. Then turn it on, off again. At some point, you may want to have this camera cleaned, lubricated and Adjusted(CLA) - after all, its over 25 yrs old.
If all that did not work, you'll need to send it in. Here are some good choices for repair places...
Garry Airapetov in Niles, ILL
Camera Repairs in Avon, IN.
BTW here's a website with several pages about FG...http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/fg/index.htm
copy and paste it into your browser.
Oct 10, 2009 | Nikon FG 35mm SLR Camera
Changing lens
Your Nikon is a SLR which stands for single lens reflex. The reflex part is the way the mirror that lets you look through the lens to frame the picture flips up to let the light go straight to the film. You can change the lens half way through the film roll because the mirror is down while you change the film and blocks light from getting to the film, just as it blocks the light until you push the shutter button. Have fun with your 'new' camera! I use an even older style Nikon FE2. I like my Nikon 55mm macro lens but your newer camera takes autofocus lenses so you'll need advice from someone else for that.
Oct 01, 2008 | Nikon F65 35mm SLR Camera
Bottom 2/3 of photo is black
It sounds like your autofocusing mirror is loose and obstructing the shutter.
Apr 03, 2008 | Canon Digital Rebel / EOS-300D Digital...
Sigma 600mm lens mount
You may be able to find a Konica toMinolta or Konica to M42 adaptor. Some adaptors are available...some aren't; it depends upon the film plane dist. and mount diameter. For instance you can get a Nikon to Canon adaptor, you can't get a Canon to Nikon adaptor. Email KonicaMinolta and ask them.
Jan 18, 2008 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Nikon D80 Digital Camera with 18-135mm Lens Logo
44 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
