I own an Olevia LED 26" TV model# S/N:velk1549e227 or fm1-026000eso4 where I can no longer adjust the picture with my remote or on the control panel of thge TV, which seems to be locked on different values than I originally preset and also cannot set the TV to the default. I can adjust the sound.
  • mck1117 Aug 24, 2010
    Why would these compnents all of a sudden puff up or fail. I have had it on my deck for most of the summer but in a covered envoirnment.
  • 11,800 Answers
The control processor of the tv has failed due to a power surge, either directly from the mains or because the power source of the tv has developed a failure - most likely a bad quality capacitor failed, shorted and the voltage to the processor spiked.
This is unfixable, the mainboard (on which the processor is soldered) must be replaced. On such an old tv i don't think it's worth it - time for a new one.
Posted on Aug 24, 2010
  • 5,138 Answers
Problem will be the Main Board the one that has the tuner and AV outputs on it,where you connect cable too.
Encompass Parts Distrbution Might have it in stock
look on their website and type in your model number that is printed on back of TV. 1-800-638-3328
Also CK power supply baord for Bad capacitors they will be vented swollen or puffed up on Top if you see any that look like that they are bad.
Posted on Aug 22, 2010
  • 2 more comments
  • ladywinn
    ladywinn Aug 24, 2010
    Defective capacitors are the number one failure cause for most of the lcd,flat screens plasma,projections,and DLPs TVs.
    How much does this part cost and to repair such a problem?
  • ladywinn
    Capacitors cost 59.cent up to $2.00 Mats Electronics has them 1-800-628-1118
    Radio shack has them sometimes or any local Electronic supply store.
  • ladywinn
    What is the Model number printed on back of your TV?Have you went to Ebay and looked under Electronics /Parts TVs?
I was given an olevia LCD tv from a friend of mine, I am trying to find out what the model # is, the remote says olevia RC-LTL? I am pretty sure it is a 26" or 27"
You can find the model number and the serial number of the TV on the back cover of your television.
Hope this helps. Thanks for using FixYa.
May 24, 2010 | Olevia LT26HVX 26 in. LCD Television
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Feb 21, 2010 | Olevia LT27HVX 27 in. LCD Television
Need remote control code to operate tv
Phillips make a universal remote that i used for my Olevia tv. I bought it at rite aid of all places.
Dec 23, 2009 | Olevia LT26HVX 26 in. LCD Television
Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Sep 13, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Hooked up DVD player to Olevia 26 inch TV connected correctly don't know what to put tv on to see DVD picture?
What input did you plug the DVD player into on the back of the tv? Check what it is called (AV = Composite i think), and switch to it using the Input button on the tv remote (not the cable box remote).
Jun 29, 2009 | Olevia Televison & Video
Hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Remote Codes 506 or 127
Direct TV (Remote Model RC-64RB)
Remote Codes 11144, 11240, 11331, or 11610
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
Jun 02, 2009 | Syntax Olevia 226T 26 in. LCD Television
I do not have a remote control for my tv i have adjusted the picture with only the keys on the tv i need an answer how to make the picture nstretch it looks better small i do not have a hdtv cable box
call RCA's Parts : 800-338-0376
I believe the part number for the remote is 26-4852 I dont know how much it is.
Bestbuy also has it for $14 for the remote. just call 888-BES-TBUY and go to their parts department.
Aug 18, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Verizon remote
Olevia TV's are great but, there don't seem to be any universal remotes that ca be programmed to operate them. I know I looked for my parents on thiers.
Jan 26, 2008 | Olevia LT26HVX 26 in. LCD Television
Olevia series 2, 26" LCD TV remote control device code for DISH remote control
well in most tv the dish remote control reconice the code automaticaly just press the tv button then press the power button and press de up arrow button (the one with the square over the select button) until the tv get off then press the # button to save the code try this.... good luck..and rate me
Jan 04, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
