Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
The left side of my refrigerator is getting too cold and freezing my vegetables, even in the drawer, and now the water dispenser does not work. It appears that the line is frozen. It was slow this morning, then after running a bit, it got better, but with no use for a few hours it is again not working. I changed the water filter (5 months old) and lowered the refrigerator temp to 2. I also put on the humidity control and it just seems to get worse. There is plastic tubing toward the back (inside the fridge) that appears to have frozen water in it. This is a Trio 25' bottom Freezer/Refrigerator. Model #59675529400. 5 1/2 years old.
  • 1 more comment
  • ksw1000 Aug 21, 2010
    Is this something that is easy for an unhandy person to do? If so, how?
    you suggested replacing the thermostat. Is this something anyone can do? I am not very handy. If so, how?
    ok - I turned the temp down to 1 and waited an hour or so. now the water is coming out - like some of the ice melted and the fridge IS warmer. That doesn't sound like it is running non stop, does it? Ideas?
  • 11,800 Answers
The thermostat is faulty (it's keeping the compressor constantly on) so the temperature goes below the minimum recommended and al the parts that hold water are freezing.
Replace the thermostat and all will return to normal.
Posted on Aug 21, 2010
  • Azrael SRL Aug 21, 2010
    No, it's not an easy operation, you must practically remove the inside of the freezer to do it and work around very brittle parts. Being handy is a must. In your case calling a repairman is mandatory, replacing an interior panel you broke by accident would be very expensive,
    At 1 the compressor should still be working, no ice should melt. In your case it has been completely shut down = yes, the thermostat is defective and must be replaced.
Electrolux 23 cu ft refrigerator (EW23CS65GS1) Water dispenser problem. The water dispenser on the freezer door does not dispense water but the ice dispenser is working fine. I turned off my refrigerator...
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Oct 17, 2011 | KitchenAid 20.3 cu.ft. Counter-Depth...
2 problems
Do your vegetable keeper drawers have humidity controls?
Jun 13, 2008 | GE Profile¿ Arctica® Energy...
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
My Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator bottom meat section and veggie drawer is freezing my meats and vegetables. Why?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
