Question about Frigidaire ATF6000ES Front Load Washer
Drum will not spin in any selection, is it a belt?
  • Frigidaire Master
  • 17,130 Answers
If you think the mtor is running then you can think of the belt, but if the motor is not running but the washer is turning on with all other functions in place then it is possible that the motor starter capacitor is defective.
Please check the motor for leak or open winding , but if the motor hums without running then it is for sure that the capacitor is faulty.
Howeever if the motor voltage is absent totally, then the drive to motor from the control panel is absent.
It will be failure of the driver.
Hope you check on this advice.
Posted on Aug 21, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
M/c won't spin
Take off top and rear half of machine cover
remove belt and spin drum by hand, (does it spin freely?)
make sure pump and drain hose are ok (clear)
there is a plastic ball (about egg size) in hose from drum to pump.
check motor brushes are at least 3cm long
if you have checked all these but the fault persists email me on andynj42@yahoo.com
Feb 09, 2010 | Zanussi F1245W Front Load Washer
The drum does not spin, the blower works, the gas will fire up, belts look to be in tact but may be loose?
Most gas dryers have a tensioner on the drive belt under the drum a metal bar with a teflon pully that is spring loaded to tension the belt. Try spining the drum by hand if it spins freely the belt may have come off the tensioner or it may be streched. If it doesn't turn the drum rollers or bushing may be bad. Without a make and moddel # it's hard to say
Hope this helps
Please leave feedback
Dec 04, 2009 | Dishwashers
Frigidaire ATF6000ES Front Load Washer Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
