Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out, cleaned it and lubed the tracks with white lithium grease. When that didn't work I replaced the rubber seal, which left an even bigger gap. The gaps are along both sides. It looks like the bottom of the drawer shuts completely but the top does not.
  • 1,543 Answers
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Posted on Aug 21, 2010
Testimonial: "Absolutely right! The drawer was not inserted properly on the rail. Thanks so much!"
It's a Viking freezer, not refrigerator. I know it is an older model but I don't know the model number. Ice forms on the coils on top of the freezer and the temperature inside the unit rises to...
VCBB363SS is a refigerator on top with a large door that opens and has a pull out drawer below that is a freezer
25 is too warm for freezer section
are coils snowed over complete or just on top 2 passes
if snowed solid defrost problem
if only snow on top fc fan is not running or system low on charge low side leak
unrelated if your mod is correct there is a hinge recall that should have been replaced
May 30, 2017 | Viking Professional VCBB363SS Stainless...
I have a Kenmore Elite Model 106.57863801 side by side stainless steel fridge. The doors squeak when opening and closing. How can I remedy this?
Good day,
Spraying a good lubricant on the hinge pins should solve your problem. Sprays like WD-40 shouldn't be used because they may come in contact with your food.
I suggest you call around to your local appliance parts houses to see which one's carry a "food compatable" spray.
It's safe to use around food and can be saved for future use. Most service techs I know carry it with them in the service truck to use when needed.
Oct 05, 2010 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator door left open for 11 days, now when closed it makes a loud vibrating noise, what could be the cause?
Because the door was open a large amount of moisture would have been introduced to the evaporator. This moisture would condensate and freeze behind the back walls and cause ice build up on the fan motors and in the dampers. The best way to bring this back to normal is to turn the frig off for 24 hours with the doors open and food out of it. This will unthaw the ice. If you do not eliminate all the hidden frost and ice the frig will not operate to it's full potential.
Jun 19, 2010 | Kenmore 73503 Stainless Steel Bottom...
How do I remove the freezer drawer
Remove phillips head screw from side of drawer supports, near the door. Lift door up and off the support rails. (easy to get off, sometimes a bit harder to get back on)
Jun 13, 2010 | Kenmore 73503 Stainless Steel Bottom...
I have the freezer set at 3. There is ice forming all around the door and snow like frost on the food.
Frost buildup on food and ice around the door is due to warm air infiltration. This sounds like a door closure problem. Be sure that nothing is interfering with the drawer as it closes. Be sure to open the upper door and look down at the drawer top to see that the gasket is hitting the steel frame of the cabinet. Look all the way around the entire drawer front checking the seal.
Also open the drawer and hold it as it closes, so that if there is any food product binding it you will see it get hung open.
Good luck.
Jun 13, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
I need to replace the stainless skin on my freeze
You will most likely need new drawer unit Warner's Stellian in Saint Paul, MN can help. For cleaning DeBruce Polish is the best.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Jan 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer drawer closes on right but gaps on left side for Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator, frosting contents. No contents blocking. Can manually hold left side closed, but wont...
I had this problem with my Kenmore bottom freezer drawer also. I found that the problem was I had too much weight at the very front of the drawer. Try reorganizing and moving items, especially heavier items away from the very front. Worked for me.
Jul 10, 2009 | Kenmore 73503 Stainless Steel Bottom...
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
376 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
