Question about GE GSH22SGRSS Side by Side Refrigerator
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool freezer or refrig sides.
  • 1,543 Answers
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Posted on Aug 21, 2010
Hotpoint ff200e
I would be better for the unit if you unplugged it and allow to completely thaw. Also, double check all food as salad dressings also goes bad in higher than normal temps. I reason behind the unplugging is to allow the unit to thaw and reset. 50/50 change if you close up the unit it will function as normal.
Good Luck
Mar 31, 2014 | Refrigerators
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer door not fully closed, for 24 hrs, now unit won't get cold
Depending on your local environment and the temperature where you live, if the door was open for that length of time, the freezer will probably take another 24 hours to recover and reach its operating temperature.
If the freezer was full, it might even take longer. If there were meat products in the freezer that thawed out, they may have spoiled, so be aware of that. Sometimes, some meat products can be cooked right away so they aren't wasted. All other products in the freezer should also be checked.
Jan 02, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A smell is coming from the ice dispenser. I need to open it.
Unlikely area for the smell to come from since with the unit off, there is no action in this area. Most likely cause of your smell: Residue in drain pan of freezer evap area. Remove panel in back of freezer section while unit is unplugged and clean drain and surrounding areas. Use a high concentration of bleach water and let unit air out completely after this. At some point in time, meat or related substance in your ref/freezer leaked and odor is caused by this as the unit was thawed. Use the product ICE AIDE, available at sears or by an A&E tech to continue to freshen your unit for 6 months. IF meat or some sort of undesirable juice dripped into the ice or door water dispenser, you can take this apart and clean as needed following your parts breakdown at www.searspartsdirect.com after you enter your model number off of the appliance. Make sure you work with an unpowered appliance.
Jun 14, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Side By Side refrigerator evaporator freezing up
is there good airflow around unit (should be away from wall about 2 or 3 inches on all sides) you say you cleaned under so about only thing left that can cause ice is low freon or defrost timer going out slowly
Jun 02, 2009 | Frigidaire FRS-26DR7D Side by Side...
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
FROST BUILD UP IN FREEZER AND REFER NOT COLD ENOUGH
hello.
  • Defrost the freezer
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • If you recently adjusted the temperature control, loaded the refrigerator or are in a humid location, it is not uncommon for a refrigerator to run for 24 hours or more before getting cool.
  • Mar 15, 2009 | Refrigerators
    GE Side by Side refrigerator/freezer Evaporator keeps freezing up
    Sounds like the auto-defrost timer has gone bad. In many cases, that is the cause. Check with GE service.
    Sep 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Freezer thawing and refreezing
    The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
    Jan 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE GSH22SGRSS Side by Side Refrigerator Logo
    281 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
