Question about General Electric WHRE5550H Top Load Washer
How do i drain the water from the pump of my washer for the winter months that i don't use it. It is a ge top loading whre555ok
  • 1,543 Answers
The pump will actually withstand the freezing, but to play it safe, just lay the drain hose down flat on the floor and allow the water to run out.
Posted on Aug 21, 2010
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
My GE WBSR3140D0WW top load washer fills, agitates but won't drain or spin
2 Possibilities. You have a failed drain pump, or the most likely, you have a clogged or obstructed pump or pump hose. it will n ot spin unitl the water level has reached a certain point. I have found socks in these. You will need to remove the front cover, slip a putty knife between the front cover and the top deck on the left and right side, push and at the same time pull the cover back. the drain pump is on the right side of the washer. If the pump sounds like its humming but not turning, there is something on the pump. If it sounds like its running, but no water being pumped out, then there is most likely an article of clothing stuck in the hose.
Apr 26, 2010 | GE WBSR3140DW Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
GE WJSR2050T2WW Washer fills up,Spins but won't drain out?
The most common reason for no pump out is a blockage in the pump. Best to drain as much water as possible. (even laying the drain hose down to allow as much of the water to drain out as possible) Un-plug washer. Next, open the front of the washer by using a putty knife to push in and release the clips about two inches in from each side at the seam where the front panel meets the washer top. Pull the front panel forward and lift it off the bottom pegs. Remove spring clamps from inlet and outlet of pump with a plier. Remove two pump mounting screws to allow pump removal after unplugging electrical leads. Remove obstruction from pump. Most pump bodies can be separated if necessary. Reassemble, plug back in and test.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Pump is not starting to pump water out of whirlpool ultimate 2
I suggest you purchase a lid switch from a local supplier of parts or call a local servie tech if it's just the lid switch it should not take a tech long to change it.
Dec 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Makes a grnding sound when washing(not always) & does not spin all the water
This problem happen to me a few months back--washer was 6 months old. A technician came out and told me that I must have loaded the washer after the water was in the tub. He stated that I must load my washer prior to running the water in because the water fill amount is based on weight; therefore it was now weighing too much. Go figure...have always loaded the washer with water first and clothes last. I always put clothes in first then the water--I must say, the problem has not reappear.
Hope this helps.
Nov 03, 2008 | GE Profile WPRE6100G Top Load Washer
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Apr 05, 2008 | GE WBSR3140DW Top Load Washer
General Electric WHRE5550H Top Load Washer Logo
90 people viewed this question
Top General Washing Machines Experts
Oloyede Monsuru
geapptech
Are you a General Washing Machine Expert? Answer questions, earn points and help others
