Question about GE Monogram ZVB36SHSS Stainless Steel Kitchen Hood
Went to lower the downdraft vent and it hit a pan and "jumped." When it hit bottom the motor to raise/lower the vent keeps running
  • bscones24 Aug 21, 2010
    You said that the switch that stops the motor when the vent is down was knocked out of position by the jump. Find it (it's on the lower lip) and fix it.
    Do I need to raise the snorkel unit to access the lower lip? And to lift up the snorkel unit do I need to remove the Trim?
    I may have posted this already. I took off the wire box cover and reset the gear motor (merely by pushing the magnetic [?] contact). The motor does not stay on when I plugged it back in.. However, I reattached the switch and now when I push it, the motor engages, but the downdraft does not move up. Any advice?
  • GE Master
  • 11,800 Answers
The switch that stops the motor when the vent is down was knocked out of position by the jump. Find it (it's on the lower lip) and fix it.
Posted on Aug 21, 2010
  • 1 more comment
  • Azrael SRL Aug 21, 2010
    Yes, and no - the switch is at the bottom, right next to the control box.
    Check the lifting mechanism - when it went out of tracks it might have broken (or bended out of position) the plastic collar that is attached to the snorkel that is gliding on the motor shaft.
Can't raise outboard motor up so I can trailer it
Disconnect Battery! Just For Safety.Try Turning Prop And Engage Forward Gear, Once In Gear Try Lifting Motor!!
Mar 09, 2013 | Boating
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
I have a GE downdraft vent, model #JVB94SH1SS. A couple months ago I pushed the button to put it down and it went down and up and down and up and down and up and...well you get it. I had to unplug it to...
I had the same problem. It is the switch. Hang on because that little $3 swtich is about $60 from a parts house. Sears wanted $114. If you take the switch out or disconnect the switch at the board and jumper the two leads, (12v), it should work fine. That will tell you whether it is the switch. I did it with a small screwdriver. Careful, even though it is 12v it will get yor attention. I have all GE appliances and they are all junk.
Oct 01, 2010 | GE Profile JVB67HWW 36" Telescopic...
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Driver side passenger window won't raise back up
It is either the motor of the switch. Operate the switch while listening where the sound is coming from in the door. Then while you are trying to raise the window, hit the interior door panel with some force, not enough to break anything, but hard enough to contact the motor. If it is binding it should allow the window to raise. If it is trying to raise it is probably the motor.
Sep 28, 2009 | 2002 Chevrolet TrailBlazer
I cracked my oil pan and i need to know if i need to take out my engin to change it i'm low on cash i need help
here's v6 3.8L
Section 03-01A: Engine, 3.8L 1996 Thunderbird, Cougar Workshop Manual
IN-VEHICLE SERVICE Oil Pan/Oil Pump Screen Cover and Tube Removal
  1. Disconnect battery ground cable (14301).
  1. Remove air cleaner outlet tube (9B659). Refer to Section 03-12 .
  1. Remove two bolts retaining radiator upper sight shield (8C291) and position radiator upper sight shield aside.
  1. Remove hood weather seal.
  1. Remove windshield wipers.
  1. Remove LH cowl vent screen and wiper module.
  1. Install Three Bar Engine Support D88L-6000-A or equivalent.
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. Remove front engine support insulator through-bolts.
  1. Partially lower vehicle.
  1. Raise engine and support with Three Bar Engine Support D88L-6000-A or equivalent.
  1. Raise vehicle.
  1. Remove starter motor (11002).
  1. Position drain pan.
  1. Drain engine oil.
  1. Remove oil bypass filter (6714).
  1. Remove starter motor wire, ground strap and automatic transmission oil cooler lines.
  1. Remove oil pan-to-bell housing bolts and bolts at crankshaft position sensor lower shield.
  1. Remove remaining oil pan retaining bolts.
  1. Remove steering shaft pinch bolt and separate steering shaft.
  1. Position transmission jack under front sub-frame (5C145).
  1. Remove six rearward bolts on front sub-frame. Loosen two forward front sub-frame bolts.
  1. Remove lower shock absorber-to-front suspension lower arm bolts and nuts (both sides).
  1. Lower front sub-frame.
  1. Remove oil pan (6675).
  1. Empty any residual oil from oil pan.
  1. Remove oil pump screen cover and tube retainer bolts and support bracket nut. Remove oil pump screen cover and tube (6622) and discard oil pump inlet tube gasket (6626).
Apr 14, 2009 | 1996 Ford Thunderbird LX
Ge downdraft vent
try removing the switch from the ribbon connector, and then jumping the two pins momentarily with a screwdriver blade or other metallic tool. It could be that the switch itself is bad. This is the same problem I'm having and I am currently looking for a replacement switch online.
Jan 23, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
GE Monogram ZVB36SHSS Stainless Steel Kitchen Hood Logo
121 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
