Samsung DVD-V4700 (dvd-vcr combo)...on certain burnt DVD discs it inconsistantly will play them at times and then say it cannot play them at other times. When it won't play a disc it is very hard to get it to open and eject the disc. This may take several minutes. Is this a common problem with this problem?
  • TEDDYBEAR475 May 13, 2008
SOURCE: rca DRC 8335 dvd/vcr combo
Call this number 877 805 0519
You need to have the model number (DRC 8335) and the serial number before you call.
Apparently this model has had a lot of problems as they have set up this number specificaly for this model. They will ask you a few questions and then they will send you another unit. You will to pay to ship it yourself. You should read the reviews on
As for geting your VHS Tape out ...Hopefully when they send you a new machine they can send your tape back with it...but dont count on it.
Posted on Jul 10, 2008
  • 166 Answers
SOURCE: lg dvd vcr combo keeps
The optical pickup (laser) needs cleaning or replacing.
Posted on Dec 15, 2008
  • 319 Answers
SOURCE: DVD player disc tray won't open
loader mechanism has malfunctioned and is not user serviceable at a reasonable cost. replacing this unit would be your best bet
Posted on Mar 19, 2009
  • 11896 Answers
SOURCE: disc won't eject
The problem is either the dvd door motor is bad or the control board is having program issues. You can remove the screws to the cover of the player. Lift cover off and manually open the door and remove the disc. It is also possible that by manually pushing the door open will put the door gears back into alignment. If it doesn't it should be tested and repaired
Posted on Apr 24, 2009
SOURCE: DVD player not opening / ejecting
I have the same problem. I just want the damned thing to return my precious audio CD. I can hear a motor trying to open the tray, but something seems to be mechanically jammed.
Posted on Apr 29, 2009
I am looking for a universal remote control that will operate a Samsung DVD-V4700 DVD-VCR combo. The original Samsung remote is part number 0008A.
The remotes I use for work are made by URC. They are a bit more expensive but will control just about anything.
Dec 24, 2014 | Samsung Televison & Video
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
DVD's will no longer play
try blowing or its how you swipe your cds you should swipe up and down by a cd cleaner that might work
Apr 26, 2009 | Samsung DVD-V4600 DVD Player/VCR
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Will Not Play CD-Rs Part Deux
Checked specs- YES -supposed to play MP3's. Did you try other MP3 Audio disks in the DVD? You can try the MP3 disk in your computer to make sure it is OK. If it plays in the computer, have to suspect a problem with the DVD unit - probably the converter IC.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Will not play CD-Rs
DVD players will play CD's and MUSIC CD-R's. Some will play MP3's IF the unit is so designed. You would see the 'MP3' logo on the front.
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
