Question about GE JE1840GB-GC Microwave Oven
My little girl pushed the start button and it ran for an unknown amount of time (but less than an hour) without anything in it. We found it still running and very hot. After we stopped it, it totally powered down and now won't do anything. No lights, not microwave, nothing. Its no the house breaker, I've checked.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 22, 2010
I foolishly ran my nnct585s without anything in it, can I get the nne271m?
Panasonic microwave
how long was it on ?
both look different
nnct585s 1000 w
nne271wm 800 w ... you might find a used unit ....
Jul 03, 2016 | In Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hello; Panasonic NN-H275 Over The Range Microwave - door stuck and cannot be opened. Thank you for your help. Regards, Vasily
Dear Vasilyk,
I feel your pain. I successfully repaired mine but don't know how long it will last (3 days now). Behind the touch pad there are two arms that the push button pivots on. The arm on the right was cracked where it attaches to the back of the touch pad. This allows the arm to move/give which shortens the amount of travel the button can make when you push it. After researching glues online I settled on hot glue to repair. I am hoping it holds up to the heat but from what I found out this is about the only glue that will stick to this type of plastic. I removed the back of the button and put a substantial amount of hot glue all around the base of the cracked arm and as far up the arm as possible. The arm is now stiff again and does not flex/give. I reassembled, and low and behold, it now works again. Like I said though, I don't know how long it will last and do not have a lot of faith in hot glue. I have called Panasonic numerous times to price the part but every time I call they give me a different part number with price varying $8-$40. To get the new arms I believe the entire touch pad has to be replaced. Also I could not figure out how to remove the actual button that you push without damaging it, which does not come with the touch pad. When I release it from the rear and try to push it out through the front it seeems to catch on a lip or something, did not want to damage it so gave up. The button does not need removes to repair but I think it will need removed to replace touchpad. Hope this helps.
Jun 12, 2011 | Panasonic NN-H275 Microwave Oven
My nespresso started suddenly runnnig too short. Please help. Joe
Next time you fill your cup, try holding the button in until it gets to the desired level then let it go.
That should reset the fill amount setting so that from then on it fills to that amount when you just push the button once like you normally do.
Good luck.
Apr 16, 2011 | Microwave Ovens
Electricity is on because the colon is showing. But we can't set anything, clock, power, etc. . Cannot program anything. Beeper is beeping for two short beeps around every half hour--.
Hello. Try this. Push the clock button. Then enter the time in hours and minutes, THEN push the clock button a second time. Joe
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Oct 05, 2010 | Danby DMW753 Microwave Oven
I do not have the manual. How do I change the poiwer level on a Frigidaire Microwave model FMT116E1W
After setting the time amount before you hit the start button, push the power button with each push it should indicate a different power level if not you've got to use the keypad, for example, 50 is 50% power etc.
Sep 07, 2009 | Frigidaire Microwave Ovens
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
Sep 21, 2006 | Sharp R-230 Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
