Question about Kenmore Elite Oasis 27052 Top Load Washer
PROBLEM WITH F1 ON WAHING MACHINE. WHAT DOES F1 INDICATE.I TRIED OPENEING EWATER FAUCET MORE AND IT WORKED BUT THAN IT STARTED AGAIN WITH SAME PROBLEM.
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
LG WM 1437 At the end of a wahing program it starts detecting as if starting the program again, what is the problem
If the machine after completion goes back to start, then it is a fault on the main controller unit. make sure that there is no moisture on the panel or within . use a hair dryer to heat off moisture after removing power cord for a while.If not the controller is a suspect.
Mar 13, 2012 | LG WM-2277HW Front Load Washer
Kenmore elite 110.2708 top loader wahing machine. i keep getting message F1 and i dont know wnat to do
Sep 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
When the lid is down the wahing machine does not start
go to REPAIRCLINIC.COM type in your model # and you can order from them
Jan 03, 2010 | Washing Machines
Our machine when turned on and menu is pressed it will show energy saving press again ventilate shows. no action
Hi
When the ventilate message is showing, push the water button is you have one then open the knob on the right with a cup under the steam wand. You should get ewater from the wand. If you don't get water from the wand check for a plug in the steam tip. If you don't have a plug in the steam tip, you may have a plugged flow meter.
Dec 18, 2009 | Gaggia Titanium Espresso Machine
Lg wahing machine WM2077CW a little bit of water enters cycle slowly, and i don't see soap nor water
Hi, Turn the faucets off at the wall and remove the inlet hoses. Look inside the inlet valve and see if the screens inside the valve are plugged.
I hope this helps
Vic
May 30, 2009 | Washing Machines
Kenmore Elite Oasis HE getting F1 code. What does this indicate?
your board is confused and cannot read water level, very easy fix, pull off console(three screws on rear) and remove clear hose on right side of main control. blow into with your mouth and clear tube. reconnect hose and try, if F1 continues main control will need to be replaced, Sears is offering this for free if your unit falls within a certain serial number range, Also a biggie.....You must use he soap only with the oasis....no exceptions.....
Apr 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Wt761
The first thing to check here is by opening up the top of your washer. Plug off the mains. Check to see the wires are connected to the inlet valve at the point where the water enters your machine, tighten the wires. Then shut off the wall faucet, unscrew the hoses, check the fine mesh at the machine valve entrance, clean out. Refit the hoses carefully without cross threading, open the wall faucet full to check for leaks; advisable to keep faucet fully open. Check to see that there is no leak at the dispenser end of the pipes. You are done now, try the machine (with the top open, caution)
If there is still no water, just change the inlet water valve, you can do it yourself.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
