Question about Jandy LXI 300 PROPANE POOL HEATER -
The spa heater says the spa is 118 degrees when it is not even on. When i try and heat the spa, the heater wont turn on because it thinks it is already heated? How do I fix the thermostat? Where is it?
  • 1 more comment
  • dnock1 Aug 21, 2010
    I dont know hwy the thermostat is stuck on 188 degrees? The spa hears wont even let you heat the water over 104 Degrees. Do you know ho to re set it so it accurately show the correct temp?
    Both the pool thermostat and the spa thermostat say the water temp is between 118 and 128 degrees. Do you know how I can reset the thermstat so that it works correctly?
    The thermostat suggests that the pool water and the spa water is between 118 and 128 degree when the heater has not been on. The heater wont come on because it thinks the pool and spa is already heated. Any suggestions?
    Guru:
  • 642 Answers
The thermostat is electronic. It is contained within what is called the "universal controller power interface pc board". Yeah, quite a mouthful. However it uses a sensor to measure the water temperature. The sensor is part of a set of 2, located under the water outlet on the outside of the unit. The pc board referred to is the middle part of the control board contained within the unit itself above the heat exchanger.You dont mention any error messages so I assume there arent any.
Posted on Aug 21, 2010
  • 4,323 Answers
Hi
1. Turn off the power to both the pool/spa control system and the heater unit.
2. Remove the front panel door from the front of the heater to access the raceway.
3. Run the wires from the pool/spa control system through the opening, Thermostat is located on the lower right or left hand side of the heater.
Please check this link for more details---
Jandy LXI 300 POOL HEATER Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
My Pentair Mastertemp 400 temperature is reading 20 degrees too low. I've replaced the thermistor already. Any ideas?
bummer hi limit wont do that but tep sensor will or control board also make sure water is flowing freely,
you will want to check the manifold bypass and thermal regulator
May 29, 2014 | Pentair Mastertemp Heater
Spa keeps overheating
Faulty temperature sensor should do this to.
A floating thermometer should read water temperature within 3-4 degrees of spa controller. If it is greater than that your sensor is bad.
The hi limit is an over heat sensor it does not control the temperature of the water. If the water is heating above 118 degrees and the spa is not shutting down its Hi Limit.
Jan 15, 2012 | Dream Maker Spas Pool & Spa
Our heater will not heat past 78 degrees. How do we get it to heat above that. Is there a factory set temp control problem? Thank you
Yes there is, but only a service technician is allowed to adjust it. However, the fact that you are only reaching 78 degrees makes me think something else is wrong.
Your bypass valve is probably the culprit. It is located where the Pipes enter the heater. It has a spring on it that is thermally activated to open and close. This allows the right amount of water to pass through the heater. Too much water and the water will not heat up. Too little water and the heater will vibrate and howl!
You could also have a faulty thermostat.
Also, always use a heater blanket when trying to heat a spa or pool. It will save you lots of money and time! And they are cheap!
Apr 16, 2011 | Pentair Minimax NT Heater
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
SNS appears on digital screen
This indicates the the 2 installed temp sensors are having a reading the is more than 2 degrees in difference. It is either a failed sensor, or one of the sensors is not fit snuggly into the header.
To test a sensor, turn your multimeter on OHMS or RESISTANCE and connect probes to each wire. at 80 degrees, the sensor should read 93 OHMS. At 70 degrees it should read 118 OHMS
at 60 degrees it should read 153 OHMS
Sep 05, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My spa heater is saying the spa is 126 degrees so
Use a thermometer to check the actual temp of the water to see if the units temp probe is accurate. Also what is the max temp allowed by the spas safety program...owners manual.
Thanks,
RSMITH972278
Oct 12, 2009 | Pool & Spa
Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Sep 04, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
Jandy LXI 300 PROPANE POOL HEATER - Logo
175 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
