Question about QDI Group QDI SUPERB 4FX SIS648FX SOC 478 ATX W/SN Motherboard
I need bios for QDI superb 4FX sis648fx soc 478 atx w/sn, the bios must be as image that can be installed to awdflash program. The bios I need is BIOS V 1.6 Sep-27, 2003
3 Suggested Answers
SOURCE: required maxtone make intel chipset motherboard
EP-8rda3+drive
Posted on Apr 12, 2009
  • 2226 Answers
SOURCE: DRIVERS FOR QDI P6S651 SUPERB 4LE V2.0 MOTHERBOARD
go to dogpile.com type in board number then drivers after that would will fine it that way jim
Posted on Mar 24, 2010
Where can I find the drive r to K7S746FX ?
HI..................
Part Number K7S746FX Manufacturer Legend QDI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset SiS 746FX North Bridge SiS 746FX Socket Socket A (462) Processor Types Athlon, Duron Number of CPUs 1 Front Side Bus 333/266/200MHz Memory Type DDR, SDRAM Memory Channels Single Maximum Memory 3GB External Graphics AGP8X IGP None South Bridge SiS 963L Audio 6-channel IDE 133/100/66/33 SCSI None SATA None RAID None LAN 10/100 Firewire None USB USB 2.0 Expansion Slots
BIOS
Form Factor ATX
THE LINK IS GIVEN BELOW.............
http://www.motherboards.org/mobot/drivers/Legend%20QDI/K7S746FX/
Sep 23, 2011 | QDI Group QDI KinetiZ 7T Motherboard
Can i find all drivers for this motherboard?
The QDI site is long gone
Your best bet is to identify each of the drivers using a tool called Everest (now AIDA)
http://www.lavalys.com/support/downloads/
Run this on the computrer and it will identify the components
If that does not help, you can try the forums at www.driverguide.com
You will need to register, but its free
Apr 19, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
How to flash the JetWay 939AGP-P Bios
Get this installer programs and the Bios bin file and put them onthe desktop together and open the Awdflash exe program and fallow the instructions on this site
How to update Bios
http://www.jetway.com.tw/evisn/download/update.htm
http://www.jetway.com.tw/evisn/download/bios/Awdflash.exe
Mar 16, 2011 | VIA JetWay 939AGP-P Socket 939 K8T800 Pro...
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
PEASE SEND TO ME THE DRIVERS FOR MOTHERBOARD QDI P2PE/800
the drivers are easly available in internet go to google type the model no and down load the drivers save it in to hardisk and dont forget to burn them in to cd
Nov 29, 2010 | Intel QDI P2PE/800 PRO 82845PE SOC 478 M...
ASUS A7N8X-E Deluxe Motherboard supports 1TB SATA2 HDD?
1) Grab a blank floppy, and a computer running Windows with a floppy drive.
2) Download C18E1013.zip (A7N8X-E Deluxe Latest BIOS, from Asus), AWDFLASH (Also from Asus), the latest Silicon Image SATARAID BIOS (from Silicon Image), and CBROM 2.15 (Alternative CBROM 2.15 download link)
3) Extract all the contents of everything into an easily accessible folder, preferably something like C:\bios
4) Make sure you have no other folders in this new folder. Everything must be within C:\bios, so for example there shouldn't be anything in C:\bios\BIO-003112\
5) Open a command prompt (Start -> Run, type "cmd" and hit enter, without the quotes)
6) Navigate to the folder you just created using the command "cd" (For example, if you used the folder I suggested above, you would type "cd C:\bios", without the quotes, and hit enter)
7) Now type "cbrom215 c18e1013.bin /pci 4284.bin" without quotes, and hit enter. This will take the latest BIOS for your motherboard, and merge the new SATARAID BIOS into it.
8) To make sure everything went correctly, type "cbrom215 c18e1013.bin /D". This will show a list of the modules in the BIOS. At the bottom should be a line with PCI(A), and should have "4284.bin" at the right end of that line.
9) Now put the blank floppy into the computer with the floppy drive.
10) Open My Computer, right click on the floppy drive (probably A:), and select "Format"
11) The formatting window should pop up. Check the box labeled "Create an MS-DOS startup disc" (which should disable all the other options), and click Start.
12) Click OK and close the format utility when the process completes.
13) Copy the modified BIOS file c18e1013.bin and the file AWDFLASH.EXE to the floppy disc (simply a drag and drop).
14) Close everything on the computer with the A7N8X-E Deluxe motherboard and reboot it. Make sure the computer is set to boot to the floppy drive, and that you have put the floppy in the drive.
15) Type the command "awdflash c18e1013.bin /py /sn" once you get to the "A:" prompt.
16) Press enter to confirm that you wish to overwrite the current BIOS.
17) Wait.
18) Once it says it is complete, remove the floppy, press F1 (as instructed), then reboot the machine (which should happen automatically once you press F1). Now the computer should detect the 1TB drive upon booting.
Jul 02, 2009 | ASUS Computers & Internet
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
Soltek SL-K890Pro-939 Motherboard
When you run AWDFLASH.EXE, it will first check compatibility of the new BIOS to the one installed. Thereafter before writing the new BIOS, it will ask you if you want to SAVE the old BIOS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 05, 2008 | Soltek SL-K890Pro-939 Motherboard
QDI Group QDI SUPERB 4FX SIS648FX SOC 478 ATX W/SN Motherboard Logo
300 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
