Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Need to separate the washer and dryer in a GE Spacemaker Washer/Dryer Unit
  • 52 Answers
SOURCE: GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Posted on Mar 29, 2008
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
  • 8 Answers
SOURCE: GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Posted on Jan 13, 2009
aborcass
  • 2651 Answers
SOURCE: Can you convert a 220 dryer element to a 120 ellement
no that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Posted on Feb 23, 2009
SOURCE: New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
Posted on May 29, 2009
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
My GE Spacemaker dryer will run but the washer will not start in any cycle (stacked unit)
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
Mar 13, 2014 | GE Spacemaker Washer and Dryer Electric...
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
May 29, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge spacemaker washer and dry stackable.
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer/Dryer
lincoln, there should be two clips on each side just below the top. Take a puddy knife and push in on the clips. The front panel should release and pull foward. Catriver..post back.
Mar 15, 2007 | GE WSM2480DWW Unitized Spacemaker Washer...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
