It could be the alternator. There are also a host of other things that could be the cause(s). Check the charging system to determine whether the alternator is possibly bad. A quick check is to measure battery voltage with ignition off, then again with engine running. Voltage should increase 1 - 2 volts with engine running. If voltage does not increases, then you certainly have a charging system problem.
