Question about Samsung Televison & Video
I have a samsung GH17TS monitor model: 711MP...any time i plug in a power cable no picture comes up and a slow ticking noise comes from it, the power light just flickers...any ideas what would cause this problem and how easy it is too fix???? crazy_dave_21@hotmail.com thankyou
SOURCE: Monitor keeps blank even the power lLED is on green
I suspect the problem is with the monitor itself. I have had the same problem. I reported it to Dell and they sent me a new monitor within a few days the problem resurfaced again on the new monitor. They have since sent me a new monitor and the problem has disappeared. The Dell customer service people sounded rather cagy to me when I suggested that this was a problem endemic to this model. The replacement monitor that I have had a sticker on the box that read "refurbished". This is a rather new model of monitor to already be into selling "refurbished" models. If you are still under warranty I suggest you call them. And even if you aren't, call them anyway. I sense that they know about this problem.
Posted on Nov 07, 2006
SOURCE: Proscan PS61700 Beeping no picture
I have a 60in Proscan Projection TV. My picture is out and the TV only beeps.
Brian Allen
Posted on Mar 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a 53 inch
whatsthe model number of your panasonic. Most panasonics mean convergence failure when the led blinks 3 times. Please respond to this post with your model number and I will post the correct ICs for your model and where you can get replacements with free instalation instructions
Posted on Jun 27, 2008
  • 280 Answers
SOURCE: Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Posted on Jul 25, 2008
SOURCE: samsung syncmaster 711mp will not
My samsung allso do not want to turn on so I open the monitor and change the electrolits in power section.Be cerefully there is a high voltage,
turn the cable of before repairing.
Posted on Oct 09, 2008
LG Flatron W2253v backlight blinking.
The powering off and on the back light is due to bad capacitors. Go ahead and explore the internal power supply. This is a very common issue on LCD I have fixed about 8 of these ranging from 1 yr of use to 9 yrs of use. I own 4 LCDs and have fixed 3 of them. 2-X2Gen, 1 Samsung and one Viewsonic. The latter one is running with out an issue and the one I use the most.
Once you open your lcd look for plunged capacitors. Replace as necessary. The fix should cost you less than 20 bucks
Check this pics for power supply removal, bad caps and new caps.
Well, pictures are over 4mb let me know if you are interested in seeing more pictures relating to this fix.
Mar 25, 2014 | LG Computers & Internet
Samsung Syncmaster LCd monitor hissing standbye mode takes 1hr to start up, is it faulty? is it dangerous to leave on or use more power usage???, would it be windows 7 causing it or a graphics card thanks.
The hissing sound is coming from the power supply board. It is not dangerous per say but it indicates the power supply is failing and you will begin to have more problems such as wavy picture, slow to display the picture and then finally no picture at all. We have repair guides posted on our web site at: www.ccl-la.com for several Samsung monitors and a repair kit is available for this model at: http://www.ccl-la.com/catalog/product_info.php?products_id=116 You should be able to repair your monitor if you can do a little soldering. If you don't want to do the repair yourself we do offer a repair service for this model, it runs $32 plus shipping and you can get more information about this at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 24, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
HP mx703 monitor does not power on; ticking noise
It seems that the transformer of the monitor has gone bad, as it makes a click sound. The cable could be the one which gets connect to the picture tube, or just for earthing.
Regards,
Shrey
Sep 28, 2009 | HP MX703 17 17 in.CRT Conventional Monitor
Liteview lm15w tft monitor model goes blank
It sounds like the port where the power cable plugs into is loose and shorting out. You may be able to dis-assemble the monitor and repair or replace the port. They are usually soldered in and the solder connection may have come loose. If it plus into the circuit board you might be able to fix the plug or tighten the screw if it is held by one.
Sep 27, 2009 | Dell E173FPb 17" TFT LCD Monitor
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Samsung syncmaster 711 mp will not turn on
Samsung 711MP S, Type GH117TS 17" LCD TV. Same fault - will not switch on. Check the following, On the switch mode Power supply board - Electrolitic Capactors C241, C242 and C243 (470uF 25V dc) were faulty - They were bulging at the top of the can. Replaced these three and the tv starts up ok.
Apr 21, 2009 | Samsung Televison & Video
My samsung 711mp tv/monitor wont turn on, the green light flashes but immediatly turns off again
I have this problem too. I have solve it by change all the capacitor at the power circuit board. If you need the layout picture of the circuit board just email me. yiimh@hotmail.com
Apr 20, 2008 | Televison & Video
Samsung syncmaster 711mp will not power up/ switch on
Apr 19, 2008 | Televison & Video
No video output
Aung, I have also a second hand 710N, and I have the same problem. Do you reach any solution for your monitor!?
Dec 25, 2006 | Samsung SyncMaster 710N 17 in. Flat Panel...
Televison & Video Logo
376 people viewed this question
Henry  Thomas
Henry Thomas
