Question about Refrigerators
Hi i have a ge fridge,about 3 years old model #gdl20kcsabs it started making a clicking sound and started defrosting everything. it has also been getting very hot on the outside bottom freezer panel to the point that it burns. i have checked the manuel, thats of no help! dont even know where to start. its the weekend and GE offers no emergency repair service. can you guide me. thanks
  • 1,543 Answers
Clicking sounds (not immediately preceeded by a power loss) indicate a bad relay on the mother board. Replace the mother board, WR55X10942)
Posted on Aug 21, 2010
Ge refrigerator dead
i don't suspect its h20 contamination. i've never seen that issue on a unit yet. is the fridge doing anything at all other than light up?
Aug 05, 2013 | Refrigerators
What's your problem?GE Model # GDL20KCSABS clicking sound Clicking sound
The clicking noise would generally be the overload on the compresser. Which means the compresser is locked up and unable to pump and needs to be replaced. Sorry You can install a 3in1 hard start which may free the compresser rotor and give you a little more time out of it but will need to be replaced eventually Good luck
Sep 08, 2012 | GE Refrigerators
The control board is going out . Pt # WR55X10656 . Soon , you will start having a refrig problem . Probably already started , but , not obvious yet .
Aug 26, 2009 | GE Refrigerators
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Everything in freezer defrosted
the defrost has a timmer you mite have to chang it ok
May 14, 2009 | GE GSS25SGMBS Side by Side Refrigerator
3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT DEFROSTING, CAUSING BOTH SIDED TO GET WARM. ELECTRIC CHECKED OUT ON HEATER AND THERMOSTAT. PUT IN A NEW CIRCUIT BOARD. SAME PROBLEM. NEW BOARD MAKES...
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
Mar 10, 2009 | Whirlpool ED5FHEXMQ Side by Side...
GDL20KCSABS bottom freezer loud clicking in back/lights blinking
you have a bad motherboard the clicking noise is coming from the lights relay. the part# is WR55X10656 it is a plug and play part so you can do it yourself. I got your part number through partsdirect.com its about 130.00 you maybe able to shop around and find a better price. thx for usinf fixya peyton.
If my solution helped pls rate me accordingly..
Jan 30, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
