Question about GE Monogram ZVB36 36" Downdraft Kitchen Hood
My GE downdraft (ZVB36) does not function. I had to unplug it because it make a continuous humming sound. I have looked for a reset button & could not find one.
The crank arm which raises and lowers the hood has jammed most likely against the vertical bearing guide in the center of the box.
Fix is:
a. If the hood is up, support it somehow so it doesn't crash down. Unplug the whole unit.
b. Pull off the box covering the motor and electricals.
c. Pull off the motor/gearbox assembly. Careful here, as this will release the crank arm which may still be under some load, causing the gearbox assembly to rotate on you.
d. Bend everything back into shape.
e. You may need a new crank arm or gearbox if the shaft to the crank arm is bent.
f. Reassemble. This is most easiy done if the hood is held up by someone or something.
Posted on Oct 03, 2010
I have a 48" Viking downdraft. The reset light shows red. How do I reset it?
With it plugged in pres and hold the power button down. Then unplug and do the same. Plug in and turn on.
Jun 26, 2016 | Viking Kitchen Ranges
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
AMD 121 won't shut off, or change cycles. Continuously "hums".
Did you try just unplugging from the wall outlet, and let sit for 15 seconds and plugging back in. Sort of like a re-boot on the computer? Just a suggestion.
Jun 30, 2014 | Ariston Technologies AWD 121
I have a GE downdraft cooktop and the igniters continuously click
You probably have button or a knob to press to get ignition if there is a bit of gunk stuck in there it will not come out again, you need to remove the knob and clean out whatever is in there.
Feb 27, 2014 | GE Cooktops
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Dec 29, 2009 | GE Profile WPRE6100G Top Load Washer
Can't get the wires on right
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 21, 2009 | GE Monogram ZVB36 36" Downdraft Kitchen...
Ge downdraft vent
try removing the switch from the ribbon connector, and then jumping the two pins momentarily with a screwdriver blade or other metallic tool. It could be that the switch itself is bad. This is the same problem I'm having and I am currently looking for a replacement switch online.
Jan 23, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
Kitchen Ranges Logo
604 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
