For example, it will not let me graph equations such as y=x and y=3x+3. Anything with a variable does not work.
You have to reset
• Press [2nd] [6] (MEM) [F1] [ENTER(RAM)]
• Select 1:ALL RAM
• Press [ENTER]
• Press [ENTER]
NOTE- erased half of my programs(I think only the ones in the main directory)
I tried the reseting solution and got the syntax error, until it was pointed out to me that TI-89s, unlike the others in the series, do not automatically assume that you are multiplying, so you need to have a symbol(+,-,*,/) in between each different number or it will assume that it is a single variable(ex. 2x won't work, you need 2*x, also 2(X+1) won't work, you need 2*(x+1)) hope this helps!
Go into home. then click F6, or the cleanup button. this should present the option 'clear a-z' click it and all your variables become variables again. :) enjoy
Goto home and type Define x
You have to reset the variable memory, taken from the TI website
• Press [2nd] [6] (MEM) [F1] [ENTER]
• Select 2:Default
• Press [ENTER] and Defaults Set is displayed
• Press [ENTER]
good luck
I go w/ the second solution of eygohlolz. Go to the main folder and delete the varible x & y or y1 and y2 then you should be ok
it won't let me do simple functions involving variables, as long as i place an x or y in an equation it says that undefined variable error
im trying to graph the function sinx/x and i get an "undefined variable" message.. what do i do?
i tried to reset my calculator to the default settings and that didn't change anything. i stil got the same error message about the undefined variable. its only when i try to graph in 3 dimensions, not just 2. and i tried to do define x and it gave me a syntax error
