Question about Philips 20PF9925 20 in. LCD Television
I need a power cord, someone stole the power cord off my PHILIPS FLAT TV model # 20pf9925/17s and im having a hard time finding another cord to plug up and turn on my tv. what kind of power coed do i need and where can i get one.
SOURCE: Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Posted on Aug 19, 2008
  • 2336 Answers
SOURCE: Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 20, 2008
racer7x
  • 42 Answers
SOURCE: Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Posted on Feb 08, 2009
  • 187 Answers
SOURCE: 47" Philips LCD TV will not stay on and show a picture.
Your mainboard needs to be replaced.
You can get one on ebay and replace it or get someone who can do that for you.
if you still have guarantee, it is covered, if not you will need to buy it.
Posted on May 27, 2009
  • 4 Answers
SOURCE: tv turns off and I get a red flashing light on
http://www.fixya.com/support/t891962-philips_42_flat_screen_plasma_blinking
See this solution.
Posted on Dec 31, 2009
Unable to turn on tv at the base of the tv or the remote
check make sure you have power
check the power strip is working
check electrical and power cords
unplug the tv from the wall and remove the plug from the tv
inspect the wire or plug connectors and plug areas
check the batteries for the remote, if not sure replace them all
go to fuse panel reset breaker, trip and reset breaker
than reconnect everything and try turning tv on
see if you can find reset button, push to reset
find out if the tv has a fuse, check the fuse
after all that a new tv/ see if it worth repairing most of the time it cheaper to buy new one or a referbushed unit.
Sep 17, 2015 | Philips Televison & Video
Tv dead during lightning
Could be minor or maybe done for but here goes. Some flat panel TVs have the main power cord with one of those small transformers built into the plug end that converts 120volt ac to DC power. Output voltage should be listed on the transformer tag. You need to find someone with a voltage tester and see if the TV plug end is showing DC voltage. If not the complete power cord needs replaced. If that checks out-- the next thing is to remove the complete TV back cover and look for fuses right near the power plugs into the TV. The fuses should blow out first from a lighting surge. The problem is how much of a surge you got. It may have damaged the power supply board in the TV which may need replaced. Hope this helps
Jul 12, 2015 | Televison & Video
I cannot find the place to connect power cord into the flat screen. I searched the book on line to go with the model number Philips 42pfl3603d/27 and it wasn't specific. The place where it showed is not...
I've never had this TV but from what I can find on the internet the power connector is either at mid bottom or mid top of the backside. As for the cable it should be shaped like an 8 with one half more box shape. My TV's power connecter is on the very bottom. Wish I could help you more, but without seeing this model this is all I am able to say. Good Luck.
Mar 20, 2014 | Philips 19PFL3403D/27 19 in. LCD TV
I need a power cord for philips 15"lcd flat tv pf4110
Most of the ones that plug in are fairly generic. Try to look at say MCM Electronics who has an extensive online catalog to see if they have the cord you need.
Dec 11, 2012 | Philips Televison & Video
Where can I purchase a power cord for a LG Flat Screen TV Model #32lh40-ua
Check to see if the power cord input on the TV has the same plug shape as the one that fits into your computer tower or monitor. Many modern TVs use the same standard power cord as a desktop PC or monitor.
If it does use the same cord, then you should easily be able to find a replacement cord for a couple dollars at most since that is such a common item. You or someone you know may even have a spare one lying around leftover from an old computer system.
Good luck.
Jul 28, 2011 | LG Televison & Video
I have a 42PFL3403 model (42"). Was bought brand new. After a few months, started with problems. The image went off (sound OK). At the begining was enough to turn off and turn it on again. With the...
This tv it new still under a year old?Yes.Tries take Philips warrenty repair.The tv problems,to the tv are the causes of the tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 23, 2011 | Philips 42PFL3403 42 in. TV
Error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
Dec 03, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
May 27, 2009 | Philips 47PFL7422D/37 Television
Where is the Fuse??
once you take off the back of the tv you can see where the power cord plugs in and there is a thin metal cover you pull that off and unplug the power cord from the board and right in front of that under the other metal cover you will see a small fuse with a white middle. pull it uot and get a new one. i think that is what you are looking for
Aug 19, 2008 | Protron PLTV-32 Television
Tv comes on goes off
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Feb 25, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 20PF9925 20 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
