I have a samsung sensor quick P801 800 washing machine. It won't spin dry and is making a rumbling noise on the spin cycle. What could be wrong?
  • 10,865 Answers
Hello. The transmission is going bad. This is at least a $300 repair so check to see if the machine is under warranty or has a service contract. IF it is or does great. Otherwise putting that much money into a machine that is over 3 years old is not recommended. J.
Posted on Aug 21, 2010
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Why does my washing machine make a load noise on the last 6 minutes of the spin cycle..especially when I have bed linens in.
It is not unusual for a machine to make a lot of noise and jump about when washing sheets as they can sit out of ballance in the drum. That is why the drum turns to and fro and short spins trying to balance the wash. If how ever the noise is rumbling like a big lorry going by, then I'm afraid it sounds like your drum bearings have gone. Replace bearings by an engineer or replace machine either is expensive.
Oct 01, 2014 | Samsung Washing Machines
Low rumbling noise and washer won't spin
Remove access panel and check to see if the belt is on.
Nov 12, 2012 | LG WM-2277HW Front Load Washer
Noisy & will not progress to spin cycle
The tub must pump down before it will go into spin cycle. My pump was making rumbling noises and when I took the basket out (simple process) there were a couple of bobby pins stuck in it. (kids) Cleaned it out and checked the flowpath with a wet and dry vacuum on the drain connection. Still makes the noise. There is a small zip lock bag under the control panel that describes the trouble shooting and error codes. It also says how to go through the diagnostics steps. Hope this helps.
May 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
The laundry is still wet after a normal wash cycle, because the machine doesn't get into the "high speed spin" (this has happened several times . . . have only had it 2 weeks). It has happened on full...
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Jan 09, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer making noise during spinning cycle.
why is my ge front load washer making a rumbling noise
Jan 06, 2009 | GE Washing Machines
Washing Machines Logo
355 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
