Question about Honda Garden
ENGINE CUTS OUT AFTER 1 MINUTE .NEW CARB FITTED BUT DID NOT REMEDY. COULD THIS BE AN ELECTRICAL FAULT ?
  • Honda Expert
  • 260 Answers
Honda has an oil level switch. It is possible that the switch is faulty or there is not enough oil in case. Check oil level also smell the oil to see if it smells like gas. If you have gas in the oil this problem can occur also. You may need to change the oil.
Posted on Aug 21, 2010
New engine fitted on my grande renault scenic 2004 but it has trouble starting and cuts out when going round corners
Are you low on fuel? Try running around with a mostly full tank.
Usually if a motor cuts out when going around a corner it could be low on fuel, or the pump pickup lines are shot...This also could be an electrical issue with a wire that has gotten into trouble when the engine was swapped in.
Jun 28, 2011 | 2005 Renault Sportwagon
Ok, i recently purchased a DTR 125 R 2000 model with running problems The bike will start with the choke on, then die with the choke off, the fuel/air mixture screw was mashed up so i purchased another...
Sounds like a vacuum leak is leaning out the mixture....check the intake between carb and engine for leaks...another source may be tjhe crankcase seals are leaking.
Mar 31, 2011 | 2000 Yamaha DT 125 R
Flotec intellipump keeps shutting off after running for 1 minute..then cuts back on and does the same thing..Why..?
Discharge hose is too restrictive (too narrow, too long, or too high).
Electrical supply inadequate. Pump should be plugged directly into an outlet without going through extension cord, timer, or ground fault interrupter circuit, any of which can "fool" the pump's circuitry.
Feb 10, 2011 | Garden
Original problem supplying to much fuel. Dismantled carb and fitted new kit,now engine runsbut wont rev unless on half coke.with coke right off engine cuts out.Almost as if running to lean ie air...
Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This material applies in general to other brands as well. Pictures are a little fuzzy, but otherwise should help. Good luck!
Jan 11, 2011 | Garden
Daewoo Lanos 2001 SE starts, runs briefly, misfires & stops
replace your intake air box filter (remember check to see what direction it faces) an arrow (indicating air flow direction) on the air filter should face the engine intake. next check your wide open throttle switch (located in the intake tube) for smooth flap movement or, a broken wire.
Apr 07, 2010 | 2001 Daewoo Lanos
I have fitted a new air mass metter and the engine light is still on allso the engine is slighly miss fireing shood I have done some thing else
Hi did you change the sensor or the air mass meter? try cleaning the sensor with carb cleaner! it sounds like the one you have fitted is faulty.
very common fault on this car
Regards
Dan
Feb 21, 2010 | 2001 Hyundai Accent
Citroen picasso keeps cutting out twice a week on acceleration
Sounds like an air leak or the tank pump cannot keep up with demand (the supply pump in tanks do give trouble (a pressure gauge between tank and engine would tell, make sure it is visable when driving, I used to tape it to the bonnet with masking tape.
Jun 23, 2009 | 1987 Peugeot Liberte
Cuts out
ALWAYS have a fire extinguisher at hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slides back in the throat of the carbs, move the clip on the jet needle one notch lower. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
May 05, 2009 | Hyosung RX 125 Motorcycles
N reg vw polo engine cuts out at junctions when headlights are on
first clean throttle body out with carb cleaner and some clean cloth , if the throttle flap is dirty the car will stall
Apr 14, 2009 | 2001 Volkswagen Golf
Engine runs for short period and cuts out.
Check the fuel and air mixture screws when it is running .Turn them so it almost stops then start turning them until it runs smoothly
Nov 13, 2008 | Garden
Garden Logo
170 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
