Question about Kenwood KDC-135 CD Player
My car stereo cd player no sound
Hi i have a 1995 bmw 325i and installed the kenwood stereo in it matched the wires on the harnes. everything works but the usb and the cd player. other than that everything is working good.
  • raydalo May 03, 2008
    oh and the model car stereo i have is Kenwood KDC-MP538U.
  • Anonymous Mar 15, 2014
    Kenwood stereo just displays "reading" when trying to play CD or USB
  • 132 Answers
What are you trying to plug into USB? if an iped it required Kenwood IP200 Adapter
Posted on Jul 25, 2008
Need to know if a looped ground would make it where the tuner on my car stereo works fine but the cd player only uses the subs and no other speakers work ? On a 1995 BMW 325i
It sounds to me like you are using more than one amplifier and are using the blue wire (power antenna remote turn on) to turn the amp for the rest of your speakers. The blue wire turns off when leaving tuner mode, thus turning off the amp(s).
Dec 31, 2012 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
No sound.
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Oct 24, 2008 | Kenwood KDC-MP338 Car CD Player
We just installed the Kenwood KDC-X692 in our 1993 BMW 740il. The tuner works, but the CD has no sound and the AUX doesn't work either. I'm also confused on the bluetooth ready but lack of instructions...
i'm assuming you are going through an amplifier. if so it sounds like you are using the blue wire instead of the blue/white wire to turn the amplifier on. i can't really help you with the bluetooth though.
Jan 05, 2011 | Kenwood KDC-X692 Car CD/ MP3 Player
How do i install a kenwood kdc-135 to a '96 mazda truck and i dont have a red and yellow wires or the ground
the wire colors in your mazda will not match the colors on the kenwood stereo. you need a test light to find the right wires
Feb 07, 2010 | Kenwood KDC-135 CD Player
Want to replace factory radio
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Dec 04, 2008 | 1995 Oldsmobile Eighty Eight
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Kenwood ks-122 in-dash car stereo/cd changer
For your Jetta, you may need a different wiring harness.
You need to be able to trace the wiring from the two dins on the back of the Kenwood receiver, and une the wiring diagram for the 1996 Jetta.
Perform your cross reference here for the receiver wiring:
http://www.justkenwood.co.uk/editorial/inst_rec.asp
Here's the wiring for your Jetta:
http://www.modifiedlife.com/1996-volkswagen-jetta-car-radio-stereo-wiring-diagram/
From the jetta wiring, it looks like your Right Front speaker isn't connected.
Here's the wiring for your Delta 88:
http://www.the12volt.com/installbay/stereodetail/1724.html
Happy hunting!
May 19, 2008 | Pioneer DEH-P47DH CD Player
hello chevi1981..what can happen is if whoever installed your system did not run your speaker wires properly eg if they have worn through and touching metal or a screw through the wires ,it can blow the audio ics in unit resulting in no sound.all these high powered units have above ground circuits in the audio stage .to check ,hook up a separate speaker direct to your unit,separate wiring ,if no sound, will most likely be the intergrated circuits..these will have to be changed by a tech as cd players are a beast to work on,also your 2 speaker wires should not touch one another.with your sec code if your have a removable face you may not have a code ,as removing face is your security .hope this helps
Jan 26, 2008 | Kenwood KDC-X717 CD Player
Kenwood KDC-135 CD Player Logo
243 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
