Question about Whirlpool Duet GHW9150P Front Load Washer
Code F dl - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Ghw9150pwo code
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
