What does the green wire hook to on a goodman ar30-1
    President:
  • 3,773 Answers
Green is normally the ground, attaches to the case or the wall switch screw., but color means nothing if the plug is wired incorrectly.
Check for correct wiring to the plug before attaching to ground.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 21, 2010
How the thermostat wires hooks up on the air handler its a Goodman
Include the model and serial for accurate results, that being said the standard wiring is RGYW (C)
R= (red) low voltage power from the transformer to "R" on the thermostat
G= (green) to "G" on the thermostat to the fan relay
Y= (yellow) to "Y" on the thermostat to the AC contactor (relay) coil. (usually outside in the AC unit).
W= (white) "W" on the thermostat to the heating terminal/gas valve, controller (varies with manufacture).
C= (common) not used much these days but some thermostats have to be "powered" by the low voltage transformer because they have lights, rechargeable batteries or other functions that require power.
Oct 25, 2017 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Gt0075-3revb goodman furnace red green white blue wires were do I hook two wires from air outside unit
Use blue wire from ground to one side wire to outside unit and the other wire to the thermostat
Nov 04, 2013 | Heating & Cooling
Have gt0075-3revb goodman red green white blue on furnace were to hook wires fromout unit for air
The 2 wires from outside unit one go the ground at furnace and the other go the Y from thermostat
Model
R-red wire(power)
G-green wire(fan)
Y-yellow wire(cooling)
W-white wire(heating)
O-orange wire(reversing valve for heat pumps)
C-brown or blue wire(common but optional if using batteries in t-stat)
Jul 08, 2013 | Goodman CLQ36AR49 Air Conditioner
Gooman ck30-1t need help wiring thermostat to unit
Hello, on your thermostat you should have terminals Y,G,C,R and W and each terminal should have a wire. Typically y is yellow, G is green, c is blue,R is red and W will be white. If there are only two wires at the thermostat this means heating was only used in the past and new 18/5 thermostat wire must be run from the control board to the thermostat
Jul 02, 2012 | Goodman Heating & Cooling
Need to how the power source will be hooked up, and how, it will wire into a 13 SEER Goodman Packaged Unit, with HKR-15 strips. wire size?= 15 Ft. run: panel to unit
Minim 20 amp circuit ... is this 110 or 220? You need to know.
20 amp circuit needs to have #12 wire. If 110 Volts, you need a black, white and green #12. If 220 Volts you need a black, a red, and a green. If you have anything IN the unit that needs 110 (probably not), you need black, Red, White and Green (bare) #12 wire. Definitely needs to be on a dedicated circuit. If your unit has a resistance heater (electric) you will need a 30 amp circuit (probably 220) which needs #10 wire minimum. 220 volt breakers are double. You will need two spaces in your panel box. Would not hurt to put in heavier wire (#8) protected by a 30 amp breaker ... $ is the governing factor.
Having said all of that --- you should be reminded that I dont even know what country you are in nor your prevailing voltage nor what your national or local codes require. My comments based on installing several Goodman products over several years on the Eastern Seaboard.
Aug 26, 2011 | Heating & Cooling
4 wire tstat wire hook up to unit
r to r w to w blue or yellow to y green to g
Dec 07, 2010 | Goodman Heating & Cooling
Wireing code from goodman heat and air to a Hunter 44360 programa
To get your heat going take the red wire hook it up to R on t-stat. Take white wire and hook it to W on t-stat. Take the green wire and hook it to G on t-stat. that will get you heat. Now I need for you to go to the unit where the wires hook to the furnace circuit board. I need to know what color wires go to what on the board. Might have to take off bottom panel. should only be using 4 or 5 wires. Get back with me and will complete the wiring. Be sure no wires at the t-stat are touching each other as this will short out transformer. So tape them off or cut flush so wire and insulation are flush. ken
Dec 11, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
