MY ZANUSSI FA 4412 WASHING M/C DO NOT SEWAGE WATER AWAY AFTER WASHING DESPITE SEWAGE BUTTON IS PRESSED
5 Suggested Answers
SOURCE: washing machine
wont spin
Posted on Dec 08, 2007
  • 6277 Answers
SOURCE: I have a Zanussi ZJ1217 Jetsystem Built in Washing
Buy another washing machine? Absolutely NO!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. Many washers will not go to spin or release the door lock at the end if there is water still left inside.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
  • 6277 Answers
SOURCE: i am looking manual for
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct. Good luck,
John C.
Posted on Apr 07, 2011
dasolver94
  • 26 Answers
SOURCE: Zanussi washing machine FA 621-622
make sure the wash prog has really finishe, & try to cut electricity before you open the door
Posted on Jul 02, 2011
Turns on. Fills with water, then why does it display error code e60?
Someone posted a list of codes: Error code e60 zwg 1140m
Some people say they just pressed and held the reset button for 5 seconds.
Nov 26, 2015 | Zanussi ZWF1430W Front Load Washer
Where is the fuse on a zanussi fa 626 washing machine?
Machine does not gave a fuse except at the plug
Aug 12, 2014 | Zanussi Washing Machines
Zanussi washing machine FA 621-622 or FA 626-674. I cannot open the door after the wash programme has finished
Jul 02, 2011 | Zanussi Washing Machines
What does e60 mean on a zanussi
E60 - Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Checked the electrical installation already twice to ensure adequate voltage and grounding.
Hope helps (remember to rate and comment this answer).
May 31, 2011 | Zanussi ZWF1440 Front Load Washer
Hi my zanussi 1221w washing machine stinks. I regularly empty and check the pump filter and the emergency drain. I have used calgon, bleach 95 degree empty wash cycle but it smells like there is a dirty...
check the door boot just inside the door for dark spots on the gray rubber boot and the drain hole in the boot it can grow mold where the water stands in it from previous washings and this mold will smell like raw sewage from all the soap and softener that aids in mold growth
Jul 22, 2010 | Zanussi FC1200W Front Load Washer
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
Zanussi Front Loader washing machine - FLE1216W Bad odour coming from inside the drum. Smells like stagnant water or could be sludge. Tried everything, filter is clean, ran a clear boil wash, and bleach...
I had the same prob -
This was resolved by flushing sump tubes after disconnecting them. the small one was silted up and stank like sewage.
Now have a bleebing which could be related to water levels...
doh!
Jan 05, 2008 | Washing Machines
Door Locked after FA code
Press "end of cycle" button and wait for a click or 3 minutes, they try the door. Do not force door
Dec 28, 2007 | Whirlpool GHW9300 Duet Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
