Question about Music
Hi. I have a Peavey xr800f. Where can I connect a 400 W active subwoofer?
  • Music Master
  • 5,603 Answers
If the subwooofer has only a single input, then connect it to the Monitor output which does a mix, HOWEVER the level will NOT vary with the main sliders, but only with the monitor pots... This is NOT really practical for performances.
There is no mixer built in the unit, so you might make a simple resistive mixer taking the "Master out" left and right using 1K ohm resistor from each to a common point that feeds the subwoofer. Tie the grounds of the sub and mixer together.
FOR SYSTEM SAFETY always power the mixer and active speakers or any interconnnected equipment from the same receptacle or source.
Posted on Aug 21, 2010
Which output do I use on a Peavey Musician 400 to connect to a powered mixer?
On the front panel there will be a Line Out jack. That's the connection point. You may have to experiment with the gain control on your mixer to get the levels right.
May 28, 2016 | Peavey Music
How do I find a Peavey PV 118D subwoofer manual?
YOur bet solution is to contact Peavey Customer Service. Here is their link-
Peavey com
Mar 14, 2015 | Peavey Music
Needing a CIRCUIT DIAGRAM for a PEAVEY MP 400 AMP & an AMPLIFIER BOARD
Hello , Anonymous check here
http://www.manualslib.com/manual/498729/Peavey-Mp-400.html?page=8#manual
Sep 05, 2014 | Peavey Music
Pv 2600 manual como conectar subwoofer
Peavey service is quite helpful and has most parts in stock for good prices. Call them directly at (800) 752-7896
Jun 22, 2014 | Peavey PV 2600 Power Amp
Peavey Fury 4 Quilted Bass guitar serial number 01050957
This is from the Peavey website. It indicates a date between 2001-2003. I found a date from another source indicating 2003. They Fury IV is a nice instrument!
"Offset double cutaway solid body, 21-frets, Quilted Maple top, solid maple neck with rosewood fingerboard, two VFL internally-active pickups, 3-band active EQ, single master volume, mid, bass, and treble controls, satin chrome hardware, available in Trans. Red, Trans. Blue, Trans. Green, or Sunburst finish, 34 in. scale, mfg. 2001-2003"
There is further info available from Peavey: http://www.bluebookofguitarvalues.com/Electric_Guitar_Values/Manufacturers/PEAVEY/Categories/ELECTRIC_BASS__FURY_SERIES/Models/FURY_4_QUILT_TOP?id=PEAVEY_ELECTRIC_BASS_FURY_SERIES_FURY_4_QUILT_TOP
Apr 10, 2014 | Peavey Music
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
I have just bought a peavey xr800f powered mixer but unable to get echo on mics any help would be appreciated thanks
There are SEVERAL things to set. First is setting the EFX mix for those channels you want the effects to be active. Next, select the effect you want AND the TIME for the effect and FINALLY the amount of the effect output to go to the MAIN and MONITOR outputs. Also the effect disable button below the effects needs to be in the correct state. ALL of these have to be set for using the effects on the mics.
Feb 07, 2011 | Peavey XR 8600D Powered Mixer
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Music Logo
214 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
