Question about KitchenAid Food Mixers
Need to replace worm gear. Can't access it. - KitchenAid Food Mixers
  • 4 more comments
  • chris constable Aug 22, 2010
    model no. 5kpm50
    the mixer is a KitchenAid 5KPM50 heavy duty model
    I have looked at the diagram but it doesn't help.
    I have taken pin out and thought that would allow access to the 5 screws to complete access to worm screw gear
    Thanks manual perfect for my needs.
    thanks very much. I was doing the right thing, but needed confirmation that I was right before applying the extra force needed to remove the planetary.
Click on this link below to view detailed instructions on how to replace the worm gear on your Kitchen Aid mixer
http://www.neilcrockett.com/mixer.htm
Posted on Aug 22, 2010
  • KitchenAid Master
  • 3,247 Answers
I can direct you to the assembly diagram of the case for this unit. Note Kitchen Aid is made by Whirlpool.
This should give you some idea of how the screws and pins are held together. I would suggest you take a video when you are disassembling. That way you will not miss any intricate step when you are putting it back together.
Good Luck
  • KitchenAid Master
  • 3,740 Answers
What is the Model number of your mixer please? I have several KM series service manuals. I may be able to help you.
Kelly
  • Kelly
    Kelly Aug 22, 2010
    I am pretty sure this maual will have the answer your looking for. The basic units are pretty much the same. Operating voltages are different by geographic location. I still think this will work for you.
    http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf You may have to copy and paste link and if it does not work just respond and I will find a better link. This one worked for me.
    Kelly
    Kelly
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer noisey and not going round freely
Your mixer most likely has a stripped gears, or a combination of stripped gears. The 5kpm5ewh is an international model similar to the ksm5. The gearing inside the mixer will be the same, some of the electrical parts may differ.
Your mixer has a nylon worm gear inside, this is the most common gear to strip inside the mixer. I would recommend opening the mixer and inspecting all of the gears before you place an order.
Most likely you will need the worm gear, which is available by itself (http://www.mendingshed.com/kawormgear.html) or you can get it in the whole worm drive pinion gear assembly (http://www.mendingshed.com/kitchenaidgearassy.html) the whole assembly is a lot easier to replace, and will save you a lot of time. You may also need to replace the grease inside your mixer, KitchenAid recommends the Benalene 930-2 food grade grease, it is only available in a 30oz can (http://www.mendingshed.com/kagrease.html) And you will also need to replace the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To aid you in your repair, here is a link to the KitchenAid service manual (http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf) This will walk you through how to take apart the mixer, replace the gear, grease and gasket, and reassemble the mixer.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
THE MENDING SHED, HELPING YOU GET THE JOB DONE SINCE 1971.
Apr 09, 2013 | KitchenAid Pro-Line Heavy Duty Lift Bowl...
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer makes a clicking noise and beater stops turning or mixing...gear seems to be slipping...
The only part that consistently wears out is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out and becoming chipped. The clicking noises you hear are made by the Worm Gear banging on the Follower. All the teeth of the Follower are now damaged and the Planetary stops rotating.
Removal and replacing of the Worm Gear Follower is no easy task. Let me know if you need help.
(Do not try to remove the Planetary assembly by forcing it with a screwdriver. That is not how it's done.)
Jan 23, 2011 | KitchenAid KP2671 Professional 6 Series...
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
I caught a spoon in my kitchen aid stand mixer. The mixer will not turn, and oil leaked out of the side
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear".
When you replace the worm gear, you should be able to see if you need more grease. This will have been the "oil" you saw escaping.
Jan 30, 2010 | KitchenAid Food Mixers
Worm gear hobart slicer
What is the model number?
Apr 06, 2009 | Hobart N50 Stand Mixer
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
Replacement parts for Wolfgang Puck stand up mixer
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page:
http://www.wpcookware.com/categories.asp?cat=32
Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
Jun 20, 2008 | Wolfgang Puck Stand Mixer
Food Mixers Logo
1,156 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
