Question about Microwave Ovens
Switch for heating element on coffe pot - Microwave Ovens
    Genius:
  • 1,478 Answers
The problem posted is not clear enough to suggest solution, i guess you are looking for where to get switch for heating element on coffee pot, i will suggest you check amazon.com or ebay .com to order for the switch.
Take care.
Posted on Aug 21, 2010
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
The left two elements on my electric oven do not heat up all the way. They do not heat on high. Also the lights that indicate the elements are on do not light up. The elements are not the problem. I...
test the switch for elements and replace if necessary, before clean and tight any loose connection, or faulty connection. use the multimeter for test.
God bless you
Oct 24, 2013 | Microwave Ovens
Hope you can help me? I have lost the user manual for my kettle (Morphy Richards model 43015). Just switched it on not realising it was empty and now it won't work. I seem to think there was a cut out...
Nearly (maybe all) small appliances with a heating element are equipped with a thermal fuse. This prevents the meltdown of heating elements, most of which are encased in aluminum. These fuses are not only unreliable (China is the biggest supplier) but generally unavailable as replacement parts since they are most often spot-welded to the ends of the heating element and would have to be replaced in the same way since solder melts at a much lower temperature.
I would suggest you replace the pot.
Sep 08, 2011 | Microwave Ovens
My coffee pot quit working. it turns on but doesnt warm up or start brewing. how do i fix it
Either the heating element is open, the thermostat is open, or the overheat fuse has popped. You can probably replace the pot for what it will cost to repair it. Good luck!
Oct 09, 2010 | DeLonghi Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Vintage Manning-Bowman Percolator fix-it guy says thermostat bad
Greetings,
I have an "Atomic" globe type art deco Manning Bowman percolator from 1947. It does not have a thermostat, just a fuse.
If your pot is blowing the fuse, are you using one with the correct amperage for the pot? This pot pulls 350 watts which works out to 3.18 amps. watts/volts=amps. You'd need a fuse that would allow the heating element to generate a minimum of 350 watts before blowung.
May 15, 2009 | Welbilt MR95TW Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
