Question about Garden
My ZD28 just stopped in its tracks while mowing. I reset all levers and the parking brake and it would not start. Nothing. Pleanty of fuel and the battery is new (2 weeks old) What could be the problem.
  • 88 Answers
SOURCE: PARKING BRAKE LEVER- NO TENSION / DISC BRAKE ADJUSTMENT-OFF
If you remove the cover of the E-brake there should be a tention ajustment that you can do yourself.
Posted on May 19, 2009
rtpflh
  • 546 Answers
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Posted on Sep 28, 2009
ftw1952
  • 10319 Answers
SOURCE: parking brake doesnt release
could be everything you had mention especially if you do not use your emergency brakes weekly. if so check the brakes themshelves behide the wheel too
Posted on Feb 06, 2010
mickey813
  • 472 Answers
SOURCE: engine runs good but dies when brake/clutch is let
well the not moveing could be the brakes are rusted look were the break rod goes put some wd40 on that its on the side of the trans and you will need to move back and forth to free it up and the cluch break switch is bad i hope this helps you
Posted on Mar 08, 2010
SOURCE: Parking Brake Lever (Orange Plastic Lever on left side) is stuck
The parking break is associated with your foot break. Depress the foot break ALL THE WAY down, then you will find that your parking break can be pulled all the way up.
Posted on Apr 26, 2010
Two problems-dont know cause or if related or not. #1 engine backfires,stalls spits hesitate like not getting fuel
This is definitely a carburetor issue... when your rider needs more fuel and air to suffice the engine, it's not getting it. How old is the unit? When is the last time it's had the carburetor removed to he serviced...
Start there....
Nov 01, 2015 | Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
Pto suddenly stopped working on my late 90's 25 hp dlt lawn tractor
Sounds like your cable might of broken. watch the deck end of the cable when you pull the lever up. If it is not moving the pully, it is broken. If you are trying to start with lever still up, even though the deck is not running, the safety switch is usually up on the lever. Try disengaging the deck lever, sit in seat, apply brake or parking brake and turn key to start. Let me know if that doesnt work and we can go from there.
Aug 06, 2014 | Craftsman Garden
Craftsman LT 1000 Model: 917.272650 I put a new battery in over the weekend and was running perfect for most of the day Saturday. I got off it to empty the bagger, and as normal, the engine stopped. I...
check to make sure that mower deck drive is not engaged. there is a switch that the lever presses on it must be free. also check for seat switch cables loose or disconnected. Also make sure it is in neutral and not reverse as it may also kill the circuit for safety. Depends on you system for mow backwards. with key on you can short the two large terminals on solenoid to see if starter works. if so you must check all safety switches . try setting park brake before trying to start too.
May 17, 2013 | Garden
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
I have a Briggs & Stratton 13.5 HP Model: 21B807-0326-E1 on a Craftsman Riding mower. How do you adajust the Idle mixture needle valve? Fred
i find when this happens you need to take the carb apart and soak it in a carb cleaner there are jets inside that get plugged up and not enough fuel gets to the engine
Jul 06, 2012 | Garden
MTD MODEL 13AB652F729 came to a complete stop by itself while running. It felt as if I had stepped on the brake. I lifted the rear of the tractor and found that the rear wheels won't turn while the...
If it stalled while mowing long grass the drive system will need resetting. Do this by starting the mower, while in neutral place the speed lever in the highest speed setting then let you foot off the brake/clutch then back on. Place in forward and you should have drive restored. Regards Phil.
Apr 23, 2011 | Mtd Garden
I have a 2007 Cadillac CTS. I go to turn the key and nothing happens. All onboard elctronics and a/c are functional. Battery life shows to be good. I have also tried using my other key set and nothing....
Test the neutral safety switch by doing the following steps.
1)foot on brake
2)turn key to on position
3)shift lever to neutral (N)
4)start the engine
5)shift the lever to Park (P)
If the engine can start at N and not at park then it's the neutral safety switch.
Dec 01, 2009 | 2007 Cadillac CTS 3.6L
I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
Jul 23, 2009 | Garden
May 14, 2009 | John Deere Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
