Question about Ovens
Bought new cooker however no user guide its a kenwood ck404 duel fuel double oven 5 ring burner. need to know what symbols on switches are and what they do.
I have a problem with my Kenwood CK404. When I put either oven on (it's a double oven), once it gets hot it starts to make an awful noise. At first I thought it was the fan in the main oven. But it makes the same noise in the small oven, which doesn't have one. Does anyone have any suggestions of what the problem could be? Kind Regards
Trotwood
Posted on Aug 26, 2010
  • Cazzz Dec 16, 2010
    I have got the same problem. Did you find out what it was?
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
How do i connect the gas pipe to the ck404 kenwood oven
You need someone from the Gas Co, because if something goes wrong.. Your insurance will cover the Gas Instaler but not a Home Installer
Do you understand?
Jul 31, 2010 | Ovens
My kenwood ck404 rangestyle main oven has stopped getting hot, but the oven grill still works, is there a second eliment and if so how would I access it? Thank you
my kenwood ck404 duel oven the main oven does not work the light does not come on at all but the other oven works and the light is on
can you help
Jan 01, 2010 | Ovens
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
How can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Thanks.
Dec 31, 2008 | Ovens
Ovens Logo
309 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
