Question about Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP
I have a filter that leaks around the top where the bolts are. the bolts are tight. how do i fix it?
    Problem Solver:
  • 15 Answers
If you remove all the bolts.. i know.. not fun, there is a rubber gasket that the filter head rests on. Make sure its clean, wipe it good.. even the smallest amount of sand will cause a leak. After its clean, apply a 0-ring lube to it. put lid back in and snug the bolts, do not over tighten.. its a plastic filter, and will crack.
Posted on Aug 23, 2010
How to fix the oil leak on oil filter 1996 Acura
The filter maybe loose. Turn it clockwise BY HAND till its tight. the rubber ring around the top of filter should have been coated with old oil prior to install, helps it seal
OR you could have a hole in filter
Hope this helps Mike
Feb 07, 2016 | Acura Cars & Trucks
Free mechanic advice
IF the oil is leaking when the engine is running then you have a pressure leak problem. Check that the oil filter is on tight but if over tightened it will leak at the seat or around the folded lip. IF the leak is at the point where the head is on the block then do a head bolt re-tension or replace the head gasket. Check that the oil pressure sender switch is not broken and leaking.
Aug 24, 2013 | Chevrolet Cavalier Cars & Trucks
Oil leak
is it leaking from top of filter -remove filter and check o-ring for damage and check housing for old o-ring[double gasket it happens] if good check housing for cracks and that gasket is good and bolts are tight -also check the pan gasket and bolts are good
Apr 30, 2013 | 2004 Chevrolet Blazer
93 toyota lucida massive oil leak
Replace the oil ring on the oil filter or get another oil filter.. B4 screw in the oil filter apply some oil to the oil ring..
Feb 01, 2013 | Cars & Trucks
Oil leaking around oil filter housing 1995 ford explorer v6
there is 2 bolts that hold the oil filter housing to the engine, since you need to tighted it ,get the gasket it is 2 dollars
Dec 21, 2012 | Cars & Trucks
No problem just want to know the torque specs for the valve cover bolts on a 1977 ford f250 4x4 pk. I'm changining out the gaskets and dose not she to torque specs in my manuel.
Rocker arm cover bolts are usually torqued between 6-9 ft/lbs, or 88-105 inch lbs. A good wrist tight using a 1/4" drive socket is how I do them and have had great success like that. Always put all bolts in finger tight, then start in the middle of cover top then go to the bottom middle across working your way outward in and up down criss cross pattern. Go around the bolts twice. Most common for people to overtighten them and then the cover will leak again. They do not need to be extremely tight, just a good snug / wrist tight......Mike
Jun 24, 2011 | Ford F-250 Cars & Trucks
How do you change the transmission filter in a 1997 jeep loredo
If you have a pan drain plug, drain the pan. If not, remove all bolts around it's perimeter, leaving two on one edge loose but not removed. Use a large catch pan or I've seen some people use a garbage pail cover over a smaller pan with holes drilled in the center of the cover so it drains.
Remove the filter, making note of the position of the filter and screw length (if any screws are longer or shorter they must go back in the same holes)
Remove ALL gasket material from the pan and rail, clean the pan and magnet.
Reverse process to assemble. Pan bolt torque is around 14 inch pounds.
You don't need a torque wrench if you use a 1/4 inch ratchet and do not pull down hard when tightening. DO NOT crush the gasket so tight it bulges out. Install all bolts by hand before tightening, tighten in a cross pattern, not around in a circle. Re fill with the proper fluid, run the engine till warm, check level, check for leaks. Make a short test drive, re-check level and again for leaks. If any leaks, tighten the bolt closest to the leak and also the two on either side of that one.
Jul 17, 2010 | 1997 Jeep Cherokee
Fuel leak at front of engine at filter cap
these vehicles are notorious for leaking fuel at the valve on the back side of the fuel filter housing and when when the vehicle runs the fuel will cover the back side of the housing and run around the top kinda making it look as if the top is leaking. the filter kit for this vehicle comes with a new seal for the cap so if you replace the valve and replace the filter you should have no more leaks.
Jan 02, 2010 | 2002 Ford F250 Super Duty SuperCab
Fuel filter has a small leak. even afther tightin the halo bolt.?
The fuel filter has two washers that must be placed first in the banjo bolt and on top of the fuel-filter. Thus the fuel delivery line would be in the middle of those washers. The washers ensure tight sealing to prevent leakage.
You could have forgotten to wipe off the top of the fuel-filter before installing it.
Dec 18, 2009 | 1991 Honda Accord
Oil leak
a bolt goesthrough the centerof that housing that if memory serves me right is a t55 or t60 torx. it is a tight fit to get to and the bolt is hard to turn because it also has an oring on it
Feb 01, 2009 | 1993 Jeep Grand Cherokee
Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
502 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
