Question about Samsung RS2630SH Side by Side Refrigerator
The cooling fan needs replacement and while wating for the part to be located and ordered i placed a fan behind the refrigerator so that the temp will stay low and the ice maker to work, my question is will this cause the compressor to over heat and should i turn the fan off from time to time
need advisement
  • 149 Answers
Well if your condenser fan shot out, i'd advise that you shouldn't use the unit but all your doing buy putting the fan is doing the job of the defective one. but your causing more stress to the compressor and system, your forcing it to "work overtime" so technically you are cutting the compressor's life
Posted on May 04, 2008
How to remove and replace cooling fan on 05 bmw 325i
The cooling fan is held onto the plastic shroud so to remove the fan you must first remove the shroud as the motor comes out from behind closest to the rad.this 05 model doesnt have a manual centrifugal type unlike the earlier models its not a difficult job but lots of bits and bobs to remove first though
Aug 12, 2013 | BMW Cars & Trucks
How to test and replace radiator cooling fan.
Here a tip illustrating steps to test and replace the radiator cooling fan and the parts that may cause cooling fan malfunctioning.
Before replacing the fan, make sure that the fan is really faulty.
Read volts at fan contacts or jump the fan wiring to energize the fan directly.Ensure that fan blades are not blocked.
If the fan is OK, then the faulty part is either thermostat or fan relay.Ensure also that you have tested the 15A fuse in the junction block and the 40A fuse located in the Power distribution Center (PDC).
Here a diagram showing the location of the fan relay:
Finally, here below the steps required to replace the fan. The procedure is quite simple.
  • Disconnect the battery negative cable and set it apart.
  • Disconnect the electrical connector to the radiator fan.
  • Undo the bolts that hold the top fan housing and fan assembly (this is called Radiator Shroud).
  • Remove the Radiator Shroud housing.The radiator shroud will come out with the fan sliding toward the top side.
  • Install the new fan performing the operations in reverse order.
Here a diagram showing radiator shroud and cooling fan assembly:
on May 25, 2010 | 2000 Jeep Grand Cherokee
How to change the cooling fan in a toshiba laptop model p200d-139
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
My radiator fan is not working
For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
How to Replace Engine cooling Fan on car?
Engine makes noise and Cooling Fan belt Breaks?
Replace Fan Relay but still Radiator cooling fans not working?
Cooling fan relays location? says "COOLING FAN FAULT"?
How to replace radiator Cooling Fan?
Engine cooling components working?
How does Vehicles Engine cooling system works?
cooling fan not working Fuel pump relay and cooling fan relay troubleshooting?
Why Transmission fluid leaks near radiator?
Transmission fluid leaking?
How to replace Radiator?
How to replace Radiator on Car models?
How to flush cars radiator?
This details will help.
Feb 01, 2012 | 1997 Mercury Cougar XR7
2002 jeep grand cherokee larado is over heating. The cooling fanonly runs if I hotwire it. I changed th thermostat. Temp gauge is reading . Could it be the cooling fan relay if so where is it located. The...
Fan relay is located under pass headlight. Remove light assembly, use 2 1/2 " hole saw to drill hole in plastic housing ,3"from back wall, 3'' from left side.This will put you right over relay. Unscrew two bolts,replace. Relay was $40.... dealer wanted$350 to remove front bumper to replace it.
Sep 02, 2010 | 2002 Jeep Grand Cherokee
Our model HRF08W frig never cooled properly (although
Yes, there is a fan that moves cold air from the freezer compartment to the refrigerator. If this does not turn, the refrigerator compartment will not receive adequate cooling.
If the fan is turning, you should be able to hear it. It is likely located behind an access door in the freezer compartment. This door is likely held in place with screws. Remove the screws, open the door, and see if the fan is turning. If not, you will need to replace the fan motor.
Oct 14, 2009 | Refrigerators
Need to replace radiator in 1997 honda accord se. what are the steps?
First drain radiator by opening drain valve,"located on bottom corner usualy the right,but not always." If you open the overflow or remove cap this will happen much faster.For safety sake disconnect ground wire from battery,the radiator is locked down by top cover that attaches to body with generaly 4 bolts, upper and lower hoses have to be disconnected and if it is automatic the transmission cooling lines are connected in stacked fashion,"one above the other."The cooling fan has to be unplugged and it should be removable at this point,"when unplugging fan be carefull with connector so it doesn't break.reverse steps to replace making sure the bolts go in the right place and it all fits properly.the thermostat,"located behind the kneck of upper hose," should be replaced after connecting lower hose because in order to fill the block up and prevent damaging thermostat the block shoud be filled with coolant before attaching upper hose.
Apr 20, 2009 | 1997 Honda Odyssey
2000 Acura MDX Cooling fan problem
replace the fan motor asm for the correct repair dont run a wire that is a backyard mechanic solution
Jun 30, 2008 | 2004 Acura 3.5RL
Samsung RS2630SH Side by Side Refrigerator Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
