Question about GE JKP28 Electric Double Oven
My JKP28BFBB has power, as the interior oven lights come on but the control panel does not work. Also there was a pop and then some smoke was coming from the top area of the top oven. Thanks, Sandy
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: oven popped and smoked
seatie, as long as you have the breaker off to the oven you should be o.k. Sounds like something shorted to the oven cabinet. It could be the terminal connection on the heating element itself. The main board could of shorted out. Without being there it's hard to tell, but you will be fine until GE arrives as long as the breaker to the oven is off. Catriver.
Posted on Sep 20, 2007
dltatsjc
  • 54 Answers
SOURCE: Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Posted on Oct 12, 2009
Neff b1861 oven fan and interior lights not working on Circotherm settings
sounds like the control switch to me. if you have already taken it apart it's the switch with the most wiring.
Mar 21, 2014 | Ovens
My Whirlpool doudle oven #RBD305PDB14 was working fine and now the display is blank and it only would beep at you. the interior lights would come on but no use of controlls. It has been powered off at...
There is a thermal fuse at the connection for the control board.
Had the same problem. I repaired the board myself and ordered a replacement from sears parts direct. It is a repaired board not a new one but has the same warranty. You can get this board a lot faster. Here is the link. http://www.searspartsdirect.com/partsdirect/part-number/8302319R/0022/664. If you would like to repair your own board leave a post and I will help you.
Nov 20, 2011 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Wall Unit Double -oven. Part # 4451887 REV. C Control Panel doesn't work. Interior lights come on and the oven constantly beeps. We have been waiting for a replacement part for 4 months.
I have the same problem with the same part and was told by AppliancePartPros that the Control Panel would not be available to them until Feb 2012. I noticed a discoloration near a power transister and the big power resister next door (installed with about a 1/2 inch clearance to the PCB board, labeled R188 on my REV A board). The solder connections from the R188 resister to the PCB were cracked. That resister was hot when I touched it and the thermal cycling probably cracked the solder joints after 9 years. I am going to resolder those connections tomorrow and see if that resolves the problem. Do you see any burn marks near that Power transister (3 lead black package with a metal heat sink on its back (the heat sink has a circular hole above the black plastic package)?
Sep 01, 2011 | Whirlpool RBD305PD Electric Double Oven
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
GE JKP28 Electric Double Oven Logo
64 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
