Question about Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger
The line on my srm-225 grass trimmer keeps disappearing inside the hub after 5-10 minutes of use. Each time I reload it, it is only half as long. I've had the trimmer for two hours now and about to take it back. I must be doing something wrong. help
3 Suggested Answers
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
eugbug
  • 479 Answers
SOURCE: Just got a Worx GT151
Hi Dave.
When you are using a strimmer against stone or concrete you have to just barely allow the tip of the line to touch the ground. If too much of the line slaps off the concrete, any sharp edges or roughness on the concrete will tend to snap it. What you could try is heavier gauge strimmer line which might last longer. I used to use petrol strimmer line on my Black and Decker strimmer which was 350 watt rated. I'm not sure what effect it would have in the long term though and may wear the bearings due to the extra weight.
Posted on Jul 04, 2011
My echo srm 225 string trimmer line will not advance. Have rewound line and clear out grass from inside head.
Sometimes the spring may need extending as over time the bumping makes the spring lose its push tension causing no line advance
May 07, 2017 | Echo Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
Why won't the string advance?
many times it is because the string has welded itself inside the head . and we have to use pliers to help it get loose again .
Jun 17, 2015 | Echo New String Trimmer SRM-225 2 Stroke...
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
ECHO SRM 2100 GRASS TRIMMER HAS NO POWER
Carburetor is probably gummed up inside. There are very fine needle-thin holes in the spray nozzel through which gas has to flow. if they are gummed up, you will have an engine that starts, but has no power. try to take the brass nozzel out of the bottom of the carburetor, it unscrews & may be kinda tight. but take it out & clean the smallest holes with a thin piece of wire. should work great after that.
Aug 10, 2012 | Garden
I have an Echo SRM 225 and the trimmer head just throws the line . After bumping it it will not cut the line with the knife on the guard -it just keeps slapping the guard and the knife until all of the...
You are winding the line in the wrong direction. It should be wound on the spool in the opposite direction of the spin of the head during operation.
Good Luck!
Aug 07, 2011 | Echo Rapid Loader, Trimmer Head
Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger Logo
136 people viewed this question
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
