Question about Toshiba Computers & Internet
Y laptop will only work on mains power. When I put in the battery, laptop shuts down.
    President:
  • 2,653 Answers
This is either a problem with the battery or the motherboard.
If you can find someone with a similar Toshiba you can try their battery in your laptop, if it works then it's obviously a problem with the battery itself and you'll need to order a new one.
If it doesn't work then it's a motherboard problem which can be pretty expensive to fix (hopefully you're still under warranty)
Posted on Aug 21, 2010
Testimonial: "Thanks. It's a good idea to try someone else's battery as no point in buying one and having the same problem."
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Usually it is the battery went flat especially if u had your laptop for 3 years. Please test your battery if it is holding any charge. One of the sign is when you plug in main battery, and your battery seems to charging, however when you remove your main, the computer shut down instantly.
But if you plug your main and the battery doesn't charge(the indication light won't lit), it might mean you have got a mainboard problem.
Posted on Sep 02, 2010
Will not illuminate the screen upon startup.I only get the power button and a blinking Caps Lock button.
remove the laptop MAIN battery with the power cord UNPLUGGED. THEN PUT THE POWER PLUG BACK IN AND TRY AGAIN. REMEMBER TO LEAVE THE BATTERY OUT. IF IT WORKS SAFE;U SHUT IT DOWN AND REPLACE BATTERY. THEN TRY AGAIN. THIS IS A VERY VERY VERY OLD WINDOWS PROBLEM THAT GOT CORRECTED BY MICROSOFT OR THE COMPANY OF THE LAPTOP.. GOOD LUCK.
Oct 08, 2015 | Computers & Internet
HP G62-225NR does not power up ?
try removing the battery and just use mains power. If this works then shut down your laptop and put the battery back in and try again.
Oct 08, 2012 | HEWLETT-PACKARD Hewlett Packard HP G62 -...
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
The battery and power plug on leds flash orange at the same time. When I press the power button, the HDD and the ON leds come on green for a few seconds then they go off and machine shuts down without...
Your battery probably got wet. If this is the case you are going to have to deal with it by following the procedures you just outlined until you replace it due to the fault in the battery.
Jun 23, 2011 | Toshiba Satellite L455DS5976 Notebook
My hp ez4400 starts up but quickly shuts down ,
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Computers & Internet
Packard Bell Easy ONE DC Laptop Failure..
check this remove the battery , then insert it after some time , then check
Sep 03, 2009 | Computers & Internet
BATTERY NOT CHARGING
Try replacing the battery, i think the battery is defective.
May 09, 2009 | Acer Aspire One PC Notebook
Gateway 600ygr laptop
Is mains adaptor working (power light)?
Remove battery to see if you have mains power.
Aug 05, 2008 | Gateway Computers & Internet
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
Computers & Internet Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
