Question about Watches
Hi. There is water under the crystal on my Sharp watch but, it says on the back that it is waterproof to 100 ft. This watch has been very accurate and, is still, since it was purchased 8 years ago and I want to keep it. Thank you.
    President:
  • 2,501 Answers
There may have been some moisture inside the watch when igt was made or as the watch is fairly "old", the seal may have deteriorated.
Many makers recommend servicing (which includes fitting nw seals) ever 3-4 years.
You could try putting it in a warm palce foe a day or so to see if the problem disappears but if it persists, get in touch with the maker with a view to servicing it.
Posted on Aug 21, 2010
Testimonial: "Thanks for your help but, I have found a watch repair facility within walking distance from my house. You have been very helpful."
  • luckyvickery Aug 31, 2010
    Having dealt with that same moisture prob many times before, the best method I've found to get rid of the condensation is to pull the min/hr set dial to the out position and let the timepiece bask in the sun, with the set dial pointed upwards allowing the evaporated liquid to escape. It seems the common occurance leading to the trapped moisture is hot n humid conditions combatting drastic temp change....ex: chillin in A/C then steppin into hot shower, sauna, jacuzzi.....
Does the watch back for a Sharp SHP8903 twist off or pry off? I need to replace the battery.
If the back has notches, it probably is a twist off. Otherwise most likely a pry off. If in doubt, take your watch to a jeweler for battery replacement.
Jan 23, 2017 | Sharp Watches
Battery for sharp water resist watch, up to 100 ft
Open it up to identify battery type. You will have the advantage that the watch will be open when you replace with new.
Jul 24, 2016 | Watches
W to changebattery #65041g
Changing the battery on most watches is fairly straightforward and needs only the usual tiny screwdriver, insulated tweezers and a large measure of patience and good eyesight.
The main problem is usually opening the case and in the case of a quality watch that is guaranteed waterproof it really should be returned to the manufacturer for battery fitting and pressure testing. If testing isn't carried out after the case has been opened the watch realistically then becomes merely water resistant rather than waterproof.
Usually it is the back of the watch case that must be opened and in the case of ordinary non-waterproof and non-water resistant types it is a simple matter to prise the back off with a thin blade and then refit it with finger pressure.
Water-resistant watch cases that have a priseable back often need the back pressing back on with force supplied either by a purpose-made press or a large bench vice. In both cases adapters are needed to prevent damage to the case and the crystal.
A lot of watches have a back that unscrews and strictly a dedicated key, wrench or spanner is needed for this task. I have managed to overcome this problem a number of times by pressing other tools "that look as if they might do the job" into service. I cannot say what it was I used as I wandered around my workshop just trying things. I think the last time a particular circlip plier did the trick.
Simpler to take the watch and have someone else replace the battery I think.
Feb 20, 2015 | Timberland Watches
I put my 1962 Omega Seamaster (leather band, dress watch) through the washing machine... any ideas?
If you wear it and do not see condensation on the crystal then it is likely OK. Many watches are at least water resistant which may keep water out for shallow immersion. You should not attempt to open these watches yourself as they are a bit trick from what I can find.
Oct 23, 2017 | Watches
Is the Sharp watch shp5759 waterproof
No such thing as a waterproof watch in the USA. Watches are rated for resistance to different depths. If it just says water resistant it means you don't need to remove it to wash your hands. If it doesn't say anything it is water resistant.
Oct 01, 2012 | Watches
I have a EH-23GA Gold E Howard watch that I purchased from Amazon.Com 5/16/11. While working on my lawn mower I must have bumped the crystal on something. It chipped a flake off the inside at about 2...
you can get the crystal off, but not back on. There is a special tool that is used to compress the crystal to make it fit in the bezel. Besides, if a piece chipped off, it is no longer waterproof. Take it to a jeweler and he can put a new crystal on in no time. Crystals are not expensive.
Nov 02, 2017 | La Crosse Technology E. Howard Ambassador...
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
My tag heure chrono's minute and second hands turned black and moisture got in ?
mcdevito75 here, I hope you have a warrantee on your Tag Heur watch, if so, contact Tag Heur, if not, your on your own, (Sorry) sounds as though it"s lost some of it"s waterproofing ability or the seal around the crystal, usually a crystal sealer. Best Bet look for a small watch repair shop in your area, have them take a look at your watch. The Fog on the crystal is the tempersture change of the air in your watch, no watch is air proof, re-sealing the crystal should help, also, replaceing the rubber seal on the back of the watch.
Jul 18, 2010 | Tag Heuer Watches
Water under crystal
Obviously you have moisture inside the watch. If the crystal is not cracked then moisture can get in around the stem if the seal is no longer good. Although also possible is from a bad seal on the case back. These seals need to be replace every 3 to 4 years and then properly lubricated with a special silicon grease. With time, the seals will tend to flatten out and the grease will dry out. So get it serviced before the moisture will permanently damage it. Also. 330 ft is if you decend slowly. If you jump in a pool or subject it to a heavy spray, like in a shower, that is another story and they don't always keep the water out then.
Dec 12, 2009 | Watches
Can i dive with this watch?
You definetely CAN NOT dive with this watch. It is good for swimming and snorkeling only. Real divers watches withstand at least 200 meters of depths and are specialy designed for it.
One of the best affordable divers watch manufacturers novadays is Seiko. Check Seiko website and learn about divers watches and all the features they have. List of waterproof markings and explanations are also available.
Do not forget to rate, please.
Feb 12, 2009 | Casio W752V3AV men's watch
Watches Logo
81 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
