Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2008 Fat Boy with V and H big radius pipes, stage 1 air cleaner, and fuelpack unit. It idles rough sometimes when first starts but not always. Also once warmed up I stop at a light and it stalls but also not all the time. The stalling when warm up started before any change to exhaust or air cleaner. Any ideas?
  • 905 Answers
Given that the bike is fuel injected, and problem occurred before the mods were done, I would lean toward either the oxygen sensor or MAP (manifold absolute pressure) might be having a few issues. I would look at the O2 sensor first though.
Posted on Aug 22, 2010
Rough idle and popping on deacceleration 2000 HD Fat Boy
Sounds most likely an intake leak.
With engine at idle, spray a little carb cleaner around where that carb bolts to the manifold, and where the manifold attaches to the 2 cylinder heads.
If the idle speed picks up, there's your leak.
The intake rubber seals rot over time, start to crack, and allow air to enter, leaning out your carb mixture.
Feb 25, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
Codigos de falla
P1100 Manifold Absolute Pressure Sensor Range/Performance
P1102 Manifold Absolute Pressure Sensor Circuit Low Input
P1103 Manifold Absolute Pressure Sensor Circuit High Input
P1123 Lang Term Fuel Trim Adaptive Too Lean
P1124 Long Term Fuel Trim Adaptive Too Rich
P1127 Long Term Fuel Trim Multiplier Too Rich
P1128 Long Term Fuel Trim Multiplier Too Lean
P1134 HO2S Bank 1 Sensor 1 Transition Time Switch (Bank 1 Sensor I)
P1154 HO2S Bank 2 Sensor 1 Transition Time Switch (Bank 2 Sensor 1)
P1166 HO2S Bank 1 Sensor 1 Controller Adaptive Diagnosis Fault (Bank 1)
P1167 HO2S Bank 1 Sensor 1 Controller Adaptive Diagnosis Fault (Bank 2)
P1168 HO2S Bank 1 Sensor 1 Heater Power Incorrect (Bank 1 Sensor 2)
P1169 HO2S Bank 1 Sensor 1 Heater Power incorrect (Bank 2 Sensor 2)
P1372 Segment Time Incorrect
P1400 Manifold Differential Pressure Sensor Circuit
P1440 EVAP System Vent Solenoid Circuit
P1443 EVAP System Fault (Fuel Tank Cap Missing)
P1510 Idle Control Valve Opening Circuit Shorted (Coil 1)
P1511 Idle Control Valve Command Signal Shorted (Coil 2)
P1513 Idle Air Control Valve Opening Coil Circuit Open (Coil 1)
P1521 Power Steering Switch Input Circuit
P1529 Customer Snapshot Request VIA CAN
P1552 Idle Air Control Valve Closing Coil Circuit Shorted
P1553 Idle Air Control Valve Closing Coil Circuit Open
P1586 Encoding Signal Circuit Not Rationale
P1602 Serial Communication Fault with Transmission Control Unit
P1605 Rough Road Sensor Circuit
P1606 Rough Road Sensor Circuit Not Valid
P1611 MIL Request Signal Circuit Low Input
P1613 ECU Self-Test Failed
P1614 MIL Request Signal Circuit High Input
P1616 Main Relay Fault
P1623 Diagnostic Lamp Power Stage Fault
P1624 MIL On Request Signal//Cooling Fan Relay Low Circuit
P1625 Cooling Fan Relay High Circuit
P1665 Power Stage Group 'A' Fault
P1670 Power Stage Group 'B' Fault
esta codigo no lo existe in hyundai codigos
Dec 17, 2013 | 2008 Hyundai Tucson
Rough idle and stalling
it will have codes but the scanner in use doesn't have the right protocol for reading them
Indicates a faulty ambient air temp or BARO sensor so there will be codes
Aug 01, 2017 | 2008 Acura Rdx
Just started idling rough, sometimes stalling
Shot in the dark here without knowing the vehicle but it could be an Idle Air Control valve starting to fail. An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The cars computer or PCM (powertrain control module) receives information from various sensors and will output signals to adjust the idle air control motor in or out to adjust engine idle speed by controlling engine idle air. An idle air control motor can fail one of two ways, either the motor short circuits and stops working or the motor will develop high resistance and cause the idle air control motor to react slowly, either failure can cause the engine to stall at idle. When a trouble code scan is performed it sometimes won't always detect a failed or weak idle air control motor. To check the idle air control motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the idle air control should move in or out. If the idle air control motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the idle air control motor is removed clean (use aerosol carburetor cleaner) the passages the idle air control uses to control idle air speed, also inspect the idle air control for a build-up on the seating (pointed) end and clean as necessary.
Jul 20, 2011 | Mazda B2300 Cars & Trucks
Hello, My 2011 fatboy lo runs very hot. I have Vance and Hines big radius and screamin eagle stage one kit. It runs hot but it runs awsome. i wanted to put an oil cooler on the bike but was told to leave...
There's hot and there's too hot. Heat is one of the factors that shorten the life of an engine, especially an air cooled engine. You bike is equipped with the oil jets that help cool the pistons. If it were my bike, I'd take the bike to a known good high performance shop that had a dynometer, an exhaust gas analyzer, and a good mechanic that knew what he was doing with both the bike and the dyno. I'd have them run the bike up through the RPM range and check the fuel-air mixture ratio at various rpm levels. If the bike is running too lean, it'll run hot. Lean is mean but too lean is bad. The mechanic may can richen the mixture up just a bit, say from 14.2:1 to 13.7:1 and reduce the heat while maintaining the performance you want. It's worth a try.
Good luck
Steve
Jun 01, 2011 | 2011 Harley Davidson FLSTFB Fat Boy...
Code p1295
iam posting the hyundai code list i have that the vehicle manufacturer lists
Feb 10, 2011 | 2008 Hyundai Sonata
My 05 fatboy seems to run pretty good but it tops out at 90mph and the local dealer says he has done everything he can it has se pipes and breather, a stage one download a power commander and was tuned on...
yes,there is more you can do.Like a big bore kit,matched with some higher rpm cams, but remember this is a softail with the balancer motor so it will always steal some power away from the wheel.
May 12, 2010 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
Nov 20, 2008 | 2003 Harley Davidson FLSTFI Fat Boy
Lands Phones Logo
73 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
