Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
On the G3, the part that screws into the main body keeps coming undone. How do I put it back together (with the red washers) so that it stays togerther more than 5 minutes?
  • jalange Aug 21, 2010
    I don't think it is the threads being worn out. It is in the way/order that I put the pieces back together. Can you give me the order and exactly how the red washers are to be placed?
    Guru:
  • 468 Answers
I have found a link for you, please go through the link below:
http://www.propools.com/instructions_owners_manuals/G3.pdf
Thanks and regards,
Anil.B.R
Posted on Aug 22, 2010
  • 11,800 Answers
The threads in the body are worn out and the screws are loose. To make it tighter you must put something in the hole to take out the slack, like a piece of paper or some fine copper wires. You will have to do that every time after you dismantle the unit.
Posted on Aug 21, 2010
  • Azrael SRL Aug 21, 2010
    The order has no importance, the very few times i replaced it i put it just how i liked at that moment.
    To be honest i never noticed a difference on the sides of the washers. But that is easy to test: screw them all on one side, see how that works then screw them on the other side and compare the results.
    BTW here's the manual -http://www.propools.com/instructions_own...
    Thanks, I've got the manual. Appreciate your efforts.
HOW TO REPLACE THE GLASS ON THE SCANNER OF EPSON WF2540
Well, assuming you've got a new glass the printer you have pulls apart quite easily as long as you take your time and don't use too much muscles!!
It's basically put together with phillips head screws and if you carefully remove them and keep them in order it isn't too hard.
Remember not to use too much force. If it doesn't come out fairly easily then there is probably another screw that needs to be found and undone!
Jun 10, 2014 | Epson WorkForce WF-2540
Barracuda head keeps coming unscrewed from hose
Try wrapping white plumbers tape around the threads 3 or 4 times and then screw back together. That worked wonders for me when i had that problem.
Apr 05, 2013 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I had a power outage while playing a game and when power was returned the playstation3 system came back on. Afterwards a screen apeared saying to restart the system before continuing, but before I did I...
It is possible that the power outage has damaged your power supply, but there is a way of checking this. Unplug from the mains leave it for a minute, the switch at the back of the ps3 turn to the off position, plug back into the mains, turn the back switch to on to off then on and see if the console will power up, if not, and you have no warrenty left you will have to open up the ps3 there are guides on how to do this on youtube just have a search and you will find quit a few good videos, unplug again from the mains, take the top cover off, looking from the front of the ps3 on the left you will have a rubber insert, with a sticker on it, take out the rubber insert, inside there is one screw you will need a star ended srewdriver, somtimes a small alan key may do it, once undone and out put a bit of pressure on the top and slide it towards the left in should just slide and pull off, you then need a philipes or pozy drive screw driver to undo the 6-8 screws on the top of the inner housing, once they are all undone, from the back pull up and towards the front of the ps3 and it should come away, becareful not to snap the plastic clips.
There you will see the hardrive on the left and the blue-ray drive on the right, you will be taking out the harddrive there will be four screws holding in place, undo these and unplug the wires from the hdd and pull upwards it might be a bit hard because it plugs in the board with 2 prongs make sure you are careful not to go to rough it will come off, once the harddrive is out set the switch at the back to the off position and plug back into the mains, turn on by the switch at the back, what you are doing here is a hard resset once done that and the ps3 is unplugged again from the mains you can put it back together again, you same way you took it apart, make sure the screws for the inner caseing go into the right holes there will be a slightly shorter screw, make sure this one goes back into the right hand back corner, the others are all the same length so no need to worry about them, once back together plug the mains back in and power on from the back and see if it will boot, if you still have the same problem then it is likely that you will need a new power supply. hope this helps and post back what happens thanks.
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
My key won't unlocke my driver's door. Just spins the key hole. How do I fix, or replace, the keyhole tumbler. I need to know how to take off the intertior door panel, and how to get to the door's insides...
Sounds like maybe the linkage came undone. You can take off the door panel and inspect it, you'll notice right away whether the linkage came undone or if the tumbler is bad.
Roll down the window first, and if you have a handle for your window, put a flat screwdriver between the panel and the handle and gently pry it away from the door panel. If you look behind the handle, you will see a clip that needs to come off to get the handle off. Push it off with a screw driver (This can be a task!)now, put a screw driver in between the panel and the door and pry. Don't pull too hard, and any screws that you find going along the panel or in the panel (check the interior handle and arm rest) need to come out. The door will make a popping noise when you pry it, which is normal. There are spreader clips on the panels which keep it "suctioned" to the door, you're just pulling the clips out of the door. Work from the bottom to the top. When the panel is completely loose, lift the panel up at an angle. The panel "hangs" on the top lip of the door. When you put it back together, hang the panel on the top lip, line up the clips and gently "pop" it back into place, then put the screws back in.
Oct 29, 2009 | Dodge Neon Cars & Trucks
Grey screen on G3 ibook
Hi, Sorry you are having trouble,
Sounds to me like you're going to have to re-open that puppy and check all the connections, sometimes, when putting it back together, some cables are stretched and come un plugged...
Be careful, go slow...
Mar 29, 2009 | Apple iBook G3 Mac Notebook
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Washing machine wont rinse or spin keeps saying f18
I just fixed my machine through this site, it means the drainage hose is blocked.
The small access door at the front has a hose and a small screw cap. I drained the water via the hose then undone the screw cap and found it was blocked by tissue.
Put everything back and now is working.
Jul 09, 2008 | Bosch Logixx WFT 2806 Front Load...
Replace the electrical cord on kenmore 116.2651190 canister vacuum. How to?
Open the cover and keep pushing back until it pops off, remove the on/off pedal(pry it up from the back), take out the 2 screws and then the cover over the motor and cord reel will come loose. You can go to sears.com, click on the parts link, put in your model # and a page comes up, you can select the main body to see it apart, and you can select the reel cord asm. The parts list and picture will come up, you can order thru that page. To replace the cord is tricky, use a allen wretch to put in one side of the reel and lock it down, maybe in a vise. Then you can start taking it apart, careful as not to let the allen wretch go or the spring will unwind, then you would have to replace it also. Repalce the cord then put it back together again. Print out the diagram of the reel so you know how it is put together.
Feb 07, 2008 | Vacuums
Dyson vacuum
there is some thing broken it is two plastic cogs they help the front go down and stay up you will have to get a star screw driver and there should be two screws on top and two at the bottom when you have undone them all you will see what i mean take them out only if there broken if there ok put them back in place and put the top and bottom back together if there broken get new ones or put in back together and you will have to lean it up all the time if you want new ones go to www.ebay.co.uk or .com don't for get to wright down your model number its much easy good luck
Dec 27, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
WD420 Aquarius Washer Dryer
easiest way is to take complete front off easier to get to m8 what u do is take lid off now turn your timer dial until u c a screw as u look down from above now pull soap drawer out undue screws behind it front panel will now come off now open the door undue undue the screws behind he kick strip at the bottom of the washer and the 1s at the top which u can c since u took the front panel of now take the clip of which goes around the door seal edge once uve taken this of u can pull the door seal away from the body this should let the main front panel come away u can now c how to take the seal of reverse when your ready to put it back together havea advised this way b4 and its the esiest way to do if u dont know what to do have had good comments about doing it this way m8
Dec 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
74 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
