Question about AO Smith Heating & Cooling
Wiring diagram and capasitor needed for a "oa smith 323P843" blower moter?
Do you give advise on Home HVAC air handlers Blower Motor wiring or just on Vehicle wiring?
Can you take a picture of the wiring diagram on the moter and post it here?
Sep 17, 2014 | Heating & Cooling
Bosch wfr2460 washer not working after replacing motor with new motor- will not spin at all
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter?
If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
Oct 18, 2013 | Bosch Classixx WFC 2465 Front Load Washer
I have an A.O Smith SE2F01 115/220v Type C electric motor, it has 4 wires: White/Black/Blue/Red, I want to know which is which? And Does it need a capasitor?
Wiring diagram appears on side of unit.
With wire colors.
Capacitor: each electric motor has a run-winding and a start-winding with capacitor.
Both windings receive power.
The start-winding gets a surge of power from the capacitor > and this starts the motor.
The run-winding brings motor up to full speed.
Copy following link for motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
Apr 19, 2013 | AO Smith Pool & Spa
Just replaced a Hayward 2hp pool motor with a OA Smith 2hp pool motor and when i turned it on it starts to switch between high and low and it shuts off. the motor makes a tic tic sound. What do you think...
Hello
No there is no switch in the motor.Correct voltage is done by hooking up incoming power to a combination of internal wires or contacts.
There should be a wiring diagram on the cover where the hookup is.Or on the outside case of the motor.
The high and low speed doesnt make sence to me.Check the rpm of the motor it should be one rpm continueous.
Unless this is a Hvac motor and not a pool pump motor.Possible you may have been sold the wrong motor.
Usually a pool pump is 115 volts 1 speed and 1 rpm continuos duty.Unless you specify 230 volts.
Aug 09, 2011 | AO Smith 2 HP 115/230V 56C Replacement...
2006 f150.need fuse panel diagram .A friend is in urgent need of getting his trailer lights wired in directly,temporary only cuzx truck is borrowed
not sure fuse diagram would be helpful ,but there is a connection behind the rear
bumper at the tag that you can use a test light and some scotch lock wire connectors will get you underway quickly
Feb 12, 2011 | 2006 Ford F-150
Need to trouble shoot a C4SL2N134 pump motor. need wiring diagram
WD40 IS A WATER DISPERSANT AND WILL CAUSE MORE DAMAGE THAN GOOD ,IT WASHES AWAY OIL AND GREASE.. YOU MUST HAVE THE START SWITCH SET ,IT SHOULD BE CLOSED FOR START AND OPEN WHEN RUNNING.. NEW BEARINGS ARE THE ONLY GOOD FIX . YOU CAN TAKE THE BEARING IN YOUR HAND AT A SLIGHT ANGLE AND SPIN THE ROTOR, YOU CAN FEEL ANY BEARING DAMAGE THREW YOUR HAND I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Jun 02, 2010 | Smith AO Pool Pump Motor
Need wiring diagram due to toro wheelhorse 212-5 12hp not startin
Go to www.toro.com then customer care, then manuals & parts, type in model no. and see if you can find wiring diagram in the manuals.
Mar 30, 2009 | Toro Lawn Mower With Toro Power Tools
Blower motor 94 dodge intrepid inop
1.disconect battery
2. remove lower right undre panel silencer duct
3. remove the blower moter connector from the resistor block
4. squeeze the blower moter wiring gromment and push the gromment throw the blower moter housing cover
5. remove blower moter housing
6.romove the screws holding the blower moter down
to put back on do the steps back werds
Jan 03, 2009 | 1994 Dodge Intrepid
Heating & Cooling Logo
Top AO Smith Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an AO Smith Heating and Cooling Expert? Answer questions, earn points and help others
