Question about Elinchrom Cameras
Capacitors blown on 500 head - Elinchrom Cameras
No power. Fuse was blown but replaced fuse and still no power.
If fuses blown there is a case to search for short circuited active parts examples are end-transistors caused by clipping speakers cable shorts leaking or convexed capacitors but any new fuse will blowing again and again also the bridge rectifier to make dc voltage inside the power supply of the subwoofer can caused this problem
Jul 19, 2015 | Polk Audio DSW PRO 500 Subwoofer Speaker
I have a Pelco PMCL542A 42" monitor that power RED led is on but screen is black
Lcd tv's Do that when the backlight bulb is out. There should be a small panel on the back. Order a new bulb and replace it and it should work fine.
Dec 05, 2014 | Pelco PEL-PMCL542A-S 42-Inch Liqued...
How much to fix a blown head gasket on my 93 alderado
It could cost anywhere from 500-1600 dollars to fix this.... I'm very sorry that your head gasket blew. That is a very pricey job. I sure hope this helps, James Booth
May 17, 2011 | 1993 Cadillac Eldorado
On turning the tv on the green light comes on as if to turn on but never does, and the light turns red again.please help.
I had this same problem with an LCD monitor several months ago. It turned out to be a blown capacitor on the internal power supply board. If you are handy with tools and have a soldering iron it is a pretty simple and inexpensive fix. Otherwise you will likely have to pay someone to do it. I highly recommend a professional if you are uncomfortable with soldering. To replace the capacitor yourself:
1. Open the Television. This step can be a challenge as manufacturers often hide screw under stickers and labels. This allows them to tell if the unit has been tampered with. By doing this job yourself you will void your warranty.
2. Locate the power board, it will be right where your power cable connects. Inspect the capacitors on it to determine if any are blown. The top of a blown capacitor bulges outward slightly, whereas an good capacitor will be flat or slightly indented.
3. Not what type of capacitor is damaged and head over to radio shack. A capacitor is pretty cheap, no more then $5.
4. When you remove the olde capacitor, make sure to note which wire is positive and which is negatice, so when you put in the new one it is correct.
5. After soldering in the new one, the TV should work just fine.
Mar 15, 2011 | Televison & Video
How much does it cost to fix a blown head gasket??
Labor prices can vary. But you are looking at 5 hours of labor , some gaskets ,oil ,filter,antifreeze and machine shop labor to plane the head. 500 to 700 is reasonable.
Feb 01, 2011 | 1993 Honda Civic 4 Door
Hi my Acer monitor x193w powers up then goes straight back of, any suggestion would be apreciated in regard to which capacitors to replace.Thanks k.hansen
Try to look for capacitors with blown head. Other than capacitor, check for lines that might have been short circuited. If there's any check the ic or transistor connected to it.
Oct 25, 2010 | Computers & Internet
HELP HEARTBROKEN HEARTED 1994 ECLIPSE 1.8 4 CLY BLOWN HEAD GASKET
this will be a major job. Most of the top of the motor has to be taken off to get to the head gasket. I reccomend taking it to a repair shop.
Mar 01, 2010 | 2000 Ford Focus
Internal fuse blown as well as a capacitor, where can i get repaired or parts to make repairs
an electrical supply store would be the place to start. take the old parts with you as they have to have numbers off the old parts to get you the right replacements.
Jan 10, 2010 | Vornado TouchStone Vortex Heat 500 Heater
Paid $500 to replace fuel sender unit...made car worse....then they replaced fuel pressure system...made car even worse...now they say my head gasket is blown and wanting me to pay $950...can their mi
no their mistakes could not have led to the issue. just their bad diagnostics missed it to begin with. the dealers do not always have the most competent shop. i would usually tell people to stay away from them and use the other shops around. you are not the first that i have heard with problems they cannot diagnose. go get a second opinion from another certified shop.
May 20, 2009 | 2003 Nissan Sentra
Antec Phantom 500 burned out
u can buy a ps tester on ebay to make sure all rails are ok 5 bucks for it easy to use great tool to have dont have to be bunrt to have bad rail i seen it
Jan 09, 2008 | Antec Phantom 500 (PHANTOM500) 500-Watt...
Cameras Logo
43 people viewed this question
Top Elinchrom Cameras Experts
Are you an Elinchrom Camera Expert? Answer questions, earn points and help others
