Question about Nokia 6110 Cellular Phone
Everything works except the three bottom keys on the top slide. i.e the menu key, the navigator key and the clear key.
    Problem Solver:
  • 15 Answers
Better have it check with your nearest nokia wireless center,i have  the same problem with my nokia n70,it juse needs allignment.
Posted on Aug 21, 2010
My volume button doesnt work an shows no display when i turn it up and down? Everything else works.
If you have a device like the Nexus 6P or Nexus 9 running stock Android, then these are the steps required to boot into Recovery mode:
  1. Hold down the Power key and select Power off. If the touchscreen is unresponsive, then you can simply keep holding down the Power key for several seconds until the device turns off.
  2. Press and hold the Power key and the Volume down key. You should see the Android mascot on his back, a bunch of information about your device, and Start at the top of the screen.
  3. To navigate through the menu options, you use the Volume up and Volume down keys. The Power key is used to make a selection. Press Volume down twice, and you should see Recovery mode in red up at the top right. Press the Power key to select it.
  4. The white Google logo will pop up followed by the Android mascot on his back again with the words No command underneath.
  5. Press and hold the Power key and the Volume up key for around three seconds, and then let go of the Volume up key, but keep pressing Power.
  6. You should see the Android system recovery options pop up at the top of the screen. Use the Volume keys to highlight the options and the Power key to select the one you want.
Sep 16, 2016 | Audio Players & Recorders
How to reset blackberry 9320 to factory settings
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Card and press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
Jul 25, 2014 | Cell Phones
How do I reset the bios cause when I enter the setup wont let me click on it
When you go into BIOS Setup Hector, you can no longer use your mouse
You have to use the Keyboard
When you go into BIOS Setup you are automatically in the Main menu
To go on..........
There are 3 main BIOS manufacturers. Some smaller ones too, but doubt they wrote a BIOS program for your laptop.
Phoenix, Award, and AMI.
Award merged with Phoenix now.
There are also different versions produced by EACH BIOS manufacturer.
Therefore I cannot just start guiding you, without knowing.
Some examples however......
This style has the menu's across the Top.
One example - Main / Advanced / Security / Power/ Boot / Exit
Use the Left Arrow key to highlight the menu you want, then press the Enter key.
The navigation guide is at the bottom, and to the Right.
DOES NOT state navigation guide.
Tells you how to navigate around in BIOS, and how to make changes, and Save Changes.
Same thing for a BIOS Setup example, that has the menu's listed i n an order.
Standard BIOS Features (Standard CMOS Features)
Advanced BIOS Features
Integrated Peripherals
Power Management Setup
PnP/PCI Configuration
Etc.
Use the Down Arrow to highlight the menu you want, then press the Enter key.
The navigation guide at the bottom, tells you the key to press, to make changes.
THEN Save Changes.
IF you do Not Save Changes, it will be like you have done nothing at all.
It's because you HAVE done nothing at all. Just looked around, unless you save changes.
[Usually the Page Up or Page Down key; or the Minus ( - )
or Plus ( + ) key; is to make changes.
Change Value ]
You may see F12 to save changes, or a Y/N, or Yes/No
The Y is just shown as an upper case Y for clarity. Press the lower case y.
Then press the Enter key.
If everything goes bad:
Look at the navigation guide at the bottom, in BIOS Setup.
You will see a key listed to press, that is Load Default Settings.
Usually an F6, but don't quote me on that.
You made a boo-boo in BIOS Setup?
Go back into BIOS Setup. Find the Load Default Settings key.
Press it, then the Enter key.
Now you are back to square 1.
Regards,
joecoolvette
Feb 12, 2013 | Computers & Internet
ERROR MESSAGE 0xc05d1281 for the HP C6180 all in one I've tried about everything and still the same message
1.Press '*' key on the key pad, then press the '#' key and release them both.
2.Then enter '123' to enter maintenance mode.
3.then press the right arrow (beside the OK button) until System Configuration menu appears on panel.
4.Then press OK two times to clear the error condition,
5.then cancel two or three times to return to the top menu.
6. Then power off and back on, print a test page
If this does not help you then the printer need to be replaced you can call HP and talk to the Supervisor
Apr 28, 2011 | HP Photosmart C6280 Printer
How can I reset my calculator back to default? It used to say 12000 now it says 12k, and inseadt of showing 1/2 F->D it says 500m? HELP!!!!
moz-screenshot.pngTurn Calculator ON
  1. If you see no icons, press the Menu key.
  2. Use navigation keys (arrows) to highlight [Run] or [Run/Mat]
  3. The screen is cleared except for a possible [MAT] TAB at the bottom of screen (it depends on OS installed).
  4. In RUN screen press [SHIFT][MENU] to enter (SETUP)
  5. Use the down arrow to scroll down till you reach the line Display.
  6. If the display line looks as on the screen capture that means you have activated the ENGINEERING display mode (notice the /E after Norm1 or Norm2.
  7. To deactivate the ENG mode press the F4 function key below Eng.
  8. The /E option should disappear from the Display line.
Oct 30, 2010 | Casio FX-9860G Graphic Calculator
The navigator 6710 won't work as a phone only the navigation switches on. When you switch it on the screen does not show the menu or the contacts. Noen of the keys work except the start for navigation.
amazingly the auto zoom in out is not a software problem.. it's hardware problem nd that's is why nokia is not getting in to help as its gonna cost it alot. the problem is that the upper portion has become touch sensitive. the acceot key , hang up key,the two selection keys and the navigation keys are made touch sensitive "delibrately" or intensionly.
Feb 03, 2010 | Nokia 6710 Navigator Cell Phone
I need information how to activate the Navigator Keys
Hi
To change or assign the function of the Navigator buttons go to the Logitech icon in your desk top tray (bottom right hand corner), right click, this brings up a menu where you can decide how you want your keyboard to work for you.
Hope this helps. Thanks for using FixYa.
Oct 15, 2009 | Logitech USB Internet Navigator Multimedia...
Navigation/keypad issue
you need to consult one of the S.E repair shop.It seems one of the flex cable damaged inside and need to replace it
Mar 28, 2009 | Sony Ericsson w580i Cellular Phone
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
TYTN2 buttons not reponding - screen navigation fine
If a soft reset does not fix it,
Try a full hard reset:
Soft reset: Use the stylus to lightly press and hold the RESET button on the bottom of your device.
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Another Option if one of the SOFT KEY's is bad: START/SETTINGS/SYSTEM (tab)/CLEAR STORAGE.
Dec 05, 2007 | HTC TyTN Smartphone
Nokia 6110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
